Set reporting options
Oct 26, 2012 9:17 AM
    Oct 26, 2012 9:17 AM   in reply to Community Help
    My LMS provider is saying he "just" got a PDF. Is there a certain way I need to publish so that he can upload a file that records completion.
    The Quiz settings above I have done. Thank you
  • Jorma Jennings
    Jul 5, 2007
    Oct 26, 2012 9:31 AM   in reply to nora a patino
    Not sure what the PDF has to do with this question, please explain.
    As to the settings, that needs to be discussed between you and the LMS provider. Every LMS needs it's own set up to be matched in the reporting settings. Since there is no 'one-size-fits-all', the LMS provider will need to look at the settings availble and work with you to identify why the information is not coming through correctly.
    Oct 26, 2012 10:47 AM   in reply to Jorma Jennings
    Hi Jorma, Thanks for the answer.
    There are different formats to publish to. The LMS support is telling me that I need to publish to SCORM. I only see publishing options to Computer, Adobe Connect, and PDF. What format/package/options do I need to select to send an LMS that can record SCORM and AICC?
    I am missing that last piece of how to publish with SCORM tracking.
  • Jorma Jennings
    Jul 5, 2007
    Oct 26, 2012 11:07 AM   in reply to nora a patino
    You are seeing the publishing options, not reporting options. The reporting options are in the Quiz manager. Go to Quiz Manage > Reporting tab. From there you will see the options for configuring your reporting.
    You will want to publish to your computer (probably as a zip), and then pass that output to the individual pushing the content to the LMS. PDFs won't do reporting, other than the LMS can probably track that it has been accessed.
    Oct 26, 2012 11:24 AM   in reply to Jorma Jennings
    Thanks Jorma,
    Think I figured it out.
    I needed to send the published "package" not a PDF file.
    All set.
    Thanks and have a nice weekend.
    Sep 3, 2013 3:37 AM   in reply to Community Help
    I have branched quiz in my course. I have given the criterion of percentage of slides views under Reporting window. The "Complete" status is shown correctly on the LMS when the learner completes the quiz correctly.
    My problem starts when the learner does quiz incorrectly and does not go through all the slides and completes the percentage of slides, then also "Complete" status is shown on the LMS. I want learner to visit last slide of the course.
    Can you please guide/suggest me on this issue.
    Regards,
    Satish
    Sep 3, 2013 3:47 AM   in reply to satishkumar1
    What you are seeing is the expected behavior :
    "when the learner does quiz incorrectly and does not go through all the slides and completes the percentage of slides, then also "Complete" status is shown on the LMS"
    Is this you want:
    LMS should show Complete  only when user visits some % of slides including the last slide irrespective of whether he pass/fail the quiz ?
    Alpi Agarwal
    Adobe Presenter Engineering Team
    Sep 3, 2013 3:55 AM   in reply to alpi agarwal
    Yes, LMS should show Complete only when user visits some % of slides including the last slide irrespective of whether he pass/fail the quiz.
    Is there any solution for this?
    Satish
    Sep 3, 2013 4:13 AM   in reply to satishkumar1
    The only way is that you have to set the completion criteria as 100% to ensure that learner visit the last slide.
    What type of content you have on the last slide ? Can we put it somewhere in between or on the first slide ?
    If this is the case we may have some workaround.
    Alpi Agarwal
    Sep 3, 2013 11:44 PM   in reply to alpi agarwal
    I set completion criteria as 100% but because of the branched quiz, I am getting "Incomplete" status when learner attempts the quiz correctly and also visits last screen.
    And I have some instructions to the learner for taking next course, and also client wants that content on last screen only.
    Sep 4, 2013 11:28 PM   in reply to satishkumar1
    This is not possible . You cannot make the the user to forcefully visit the last slide.
    You can only ensure this if it is the first slide and the slide is locked.
    Alpi Agarwal
