kent morton
Photoshop 7 download
Oct 30, 2012 6:33 AM
I have purchased a new computer.  I have downloaded Elements 7 into new computer.  The program is installed and working. But it will not allow me to reach the edit function.  It prompts Photoshop elements 7 is not working.
why?
    Oct 30, 2012 8:23 AM   in reply to kent morton
    Because PSE 7 is not compatible with Win 7. Ask in the PSe forums. Someoen might have an idea, but generalyl you should consider upgrading to PSE 11.
    Mylenium
    Nov 1, 2012 8:59 AM   in reply to Mylenium
    Moving this discussion to the Photoshop Elements forum.
    Nov 1, 2012 10:14 AM   in reply to kent morton
    Hi kent,
    If you are using the trial version of PSE7, you should upgrade to PSE11. Here is the link to download trial version:
    http://www.adobe.com/cfusion/tdrc/index.cfm?product=photoshop_elements &loc=us
    Otherwise if you want to continue using PSE7, please try couple of probable solutions as mentioned below:
    Solution 1:
    1. Close Elements.
    2. Launch the Photoshop Elements Welcome Screen and hold down ctrl + alt + shift as you click Editor.
    3. Continue to hold the keys until you see a message box asking if you want to delete Photoshop Elements settings file; click Yes. Elements will open with default preferences.
    Solution 2: In case any network printer is attached try to launch without network or printer uninstall or make different printer as default.
    Solution 3: Try launching with anti-virus off or removing PSE from conflicting list.
    Solution 4:
    On the drive on which you have installed PSE,on my machine it is on C:
    Go  to C:\Program Files\Adobe\Photoshop Elements  7\Locales\<locale>\Plug-Ins\Import-Exportand you will find twain  plug-in. Remove that plug-in from that location and copy it somewhere  else.
    Now launch PSE and check if it works.
    Thanks.
