Unable to import audio of any kind into Flash CS6 Pro
Nov 2, 2012 8:16 AM
Hi all,
I've recorded voice over using Audition and am attempting to import the audio files into Flash CS6 - the problem is I'm given the error "One or more files were not imported because there was a problem reading them".
I have tried a multitude of different settings when saving out of Audition, including alternate file types, all with the same result.  To test further, I've tried past audio recordings used in other flash videos and I'm getting the same message.  Could someone post the ideal settings so I can test that vs having to randomly try every setting there is?  I'm running out of options (and sanity!) at this point.  Thanks
    Nov 2, 2012 10:05 AM   in reply to Geddiesburg3D@gmail.com
    When unsure, uncompressed is your friend.
    Here's a random snippit of a mp3 converted to uncompressed 44.1khz 16bit stereo WAV. Here's an .aif uncompressed of the same thing. See if they both import. If I export a mp3 from Audition I get your error. Imports fine on Mac/Win CS5.5. MP3s created in other applications work fine in Flash however (just not Audition). I use other apps though so I've had no reason to tinker.
    Nov 2, 2012 11:08 AM   in reply to Geddiesburg3D@gmail.com
    What OS?
    Those will definitely load so the problem has to be some installation corruption or something interfering with reading.
    Has this always been a problem or is this new? If it has always been a problem is a reinstall within your time limit? If not can you try nuking your preferences with this just to let Flash rebuild them. Close Flash and as soon as you restart it (the initial loading graphic), press this:
    Mac: Command+Option+Shift+Control
    Windows: Control+Alt+Shift
    Otherwise the typical apps that intercept any load operation would be Anti-Virus/Malware/Spyware apps loaded, try disabling those. Also any HD encryption or compression you may have enabled could interfere. Lastly if you downloaded the audio on the net and the file appears green in Windows, right-click->properties on the file and look at the bottom incase there's an "Unblock" button. If there is, click it to unlock the file.
    Nov 2, 2012 1:49 PM   in reply to Geddiesburg3D@gmail.com
    I have a HTPC setup and some of my apps like to run audio splitting (FFD*) and interception and initially I thought maybe you have some of those advanced libs installed and might be getting interference. I'm not sure if that applies to you.
    Otherwise instead of wasting hours/days/weeks/hair it might just be a good idea to try a fresh install of Flash. Make sure you completely uninstall the previous CS6 Flash install.
    The codecs I used are merely WAV and AIF containers. The stream is uncompressed so there is no codec. That removes your system from having a codec compatibility issue. However for good measure I always recommend installing CCCP.
    Edit:
    Ah you tried reinstalling (as I typed). Try loading this FLA which already has the WAV above in the library, see if you have any issue:
    http://www.ertp.com/tmp/SoundExample.zip
    Nov 3, 2012 6:52 AM   in reply to Geddiesburg3D@gmail.com
    You may have to as this is definitely out of the ordinary.
    Most of the reasons are already mentioned as to why most people can't import an audio file. I've encountered some strangeness with the usual issues. Encrypted/compressed filesystems, non-admin users lacking access to files, corrupt flash installs, anti-virii/malware/spyware interception, importing over a network, files downloaded from the net needing the be "Unblocked" and codec issues. None of these seem to be your issue (did you right-click on Flash and run as administrator?).
    If you have no FFD* splitters and such, calling Adobe is best, especially if it's a new purchase.
    Before you do, if you upgraded from any previous version of Flash they'd probably want to know if the older version worked for you.
    Nov 7, 2012 6:34 AM   in reply to Geddiesburg3D@gmail.com
    Quicktime is a dependancy if you wish to export MOV content but I'm really honestly suprised to see it's used beyond that being the boat anchor of performance it is. I, like you, would expect that without it AVI, WAV, etc would operate as they have absolutely nothing to do with Quicktime. If it's a dependancy then Adobe should have both warned about it in dialogs and/or included it during install. But we all know how much Adobe and Apple love each other.......
    What would be interesting is to know if removing Quicktime created the problem again.
    Good find and glad you solved your issue!
    Apr 9, 2013 1:30 AM   in reply to Geddiesburg3D@gmail.com
    Flash seems to import/decode audio using administrator privileges (or it's using another process started with admin privileges to decode it), so audio import fails when running under a regular account.
    Running Flash as Administrator fixed the issue for me, but it won't let me open audio on subst drives created by the regular user account.
