I've made an 8 minute movie in Elements 10. Trying to export the movie to my computer, I always get the error in the title after a few seconds. I've tried pretty much every filetype/preset and it all does the same thing.
Movie details
All files are from GoPro camera. Half of the footage is .MP4 video, shot at 16:9 HD, 720p resolution (1280 x 720) at 30 fps. Frame rate and Pixel Aspect Ratio are default. The other half of the footage is a bunch of time lapse from thousands of JPG images imported to Premiere in sequence and played back as video at 29.97 fps (default). I selected "Conform to: D1/DV NTSC Widescreen 16:9 (1.2121)" for the Pixel Aspect Ratio on these clips. I've used the Time Stretch tool on a few of the videos and manually adjusted the Frame Rate on a couple of the time lapses to 24 fps. For transitions and effects I have used Cross Dissolve, Dip to Black, Fade out, Crop, and Stabilizer. But not heavily. All of the audio from the clips is deleted and I added a MP3 to the soundtrack.
My system
Windows 7 Ultimate 32-bit
Hard drive: NTFS file system, 66 GB free space
CPU: Intel Xeon X3440 @ 2.52GHz (8 CPUs)
RAM: 4GB
GPU: ATI Radeon HD 4800 Series
Here is a screen grab of my timeline for what it's worth:
The whole movie plays just find in the preview window.
The time lapse footage all has the green render bar over it so you can tell how I've combined them with the regular video.
This is my first shot at editing so I'm pretty lost. I've tried to include as much info as I can, let me know if there is anything else I can provide. I would really appreciate it if someone could help me out on this. I spent a ton of time working on it and I really hope I can resolve it!
Version 10 technically doesn't support video from Go Pro cameras. It might work -- but the results, as you can see, can be sketchy.
If you're going to edit Go Pro footage, I very much recommend you upgrade to version 11.
Also, make sure any still photos you use in your project are, per my book, no larger than 1000x750 pixels in size. Oversized still images is the most common cause of program crashes and compiling errors.
GoPro http://forums.adobe.com/message/4486784
-says Cineform WITH GoPro, to convert to other formats
Thanks for the replies. I managed to export a small portion of the movie to MPEG2 of just the time lapse so I don't think there is any issue with the still images. It looks like I need to convert the raw video footage into a different format, which should be pretty straightforward. My concern now is that I will then have to pretty much redo my entire movie. Does anyone know if there is any way at all to preserve the arrangement and cuts of my clips while converting the source video?
Edit: I made a new project where I only included a couple of clips -- both time lapse and video -- the same way I did before but only about 20 seconds of footage and it worked fine. Not really sure what that means but it makes me think there might not necessarily be a problem with the file format.
Also, see the Adobe KB Article on "Error Compiling Movie:" http://forums.adobe.com/message/4172254#4172254
North America
Asia Pacific
