weston.6
can anyone help me convert actionscript 2.0 to actionscript 3.0 for my interactive sketchpad?
Nov 4, 2012 8:20 AM
Tags: #air #cs5 #as3 #cs5.5 #3.0 #action_script_3 #actionscript #flash_cs5 #flash_cs5.5 #interactive #animation #actions #conversion #cs6 #2.0 #pad #sketch #flash_cs6 #sketchpad
If anyone can get back to me I'd appreciate the help.
I've been working on making an interactive drawing pad but started from a template that was in actionscripts 1&2. but when I converted it to actionscript 3.0  there are errors.
I don't really understand coding very well and was hoping someone could help me make it work for actionscript 3.0.
Here is the code for actionscript 2.0 (it works perfectly when in the correct format)
lineThickness = 0;
selectedColor = "0x000000";
_root.onMouseDown = startDrawing;
_root.onMouseUp = stopDrawing;
function startDrawing() {
          if (_xmouse<455) {
                    _root.lineStyle(lineThickness, selectedColor);
                    _root.moveTo(_root._xmouse, _root._ymouse);
                    _root.onMouseMove = drawLine;
function drawLine() {
          _root.lineTo(this._xmouse, this._ymouse);
function stopDrawing() {
          delete this.onMouseMove;
line0.onPress = function() {
          lineThickness = 0;
line3.onPress = function() {
          lineThickness = 3;
line6.onPress = function() {
          lineThickness = 6;
colorRed.onPress = function() {
          selectedColor = "0xFF0000";
colorGreen.onPress = function() {
          selectedColor = "0x00FF00";
colorBlue.onPress = function() {
          selectedColor = "0x0000FF";
colorYellow.onPress = function() {
          selectedColor = "0xFFFF00";
colorMagenta.onPress = function() {
          selectedColor = "0xFF00FF";
colorCyan.onPress = function() {
          selectedColor = "0x00FFFF";
colorBlack.onPress = function() {
eraser_btn.onPress = function() {
_root.clear();
  • kglad
    Jul 21, 2002
    Nov 4, 2012 11:58 AM   in reply to weston.6
    var lineThickness:int = 0;
    var selectedColor:int = 0x000000;
    this.addEventListener(MouseEvent.MOUSE_DOWN,startDrawing);
    this.addEventListener(MouseEvent.MOUSE_UP,stopDrawing);
              if (mouseX<455) {
    with(this.graphics){
                   moveTo(mouseX, mouseY);
                       this.addEventListener(MouseEvent.MOUSE_MOVE, drawLine);
    lineTo(mouseX, mouseY);
              this.removeEventListener(MouseEvent.MOUSE_MOVE,drawLine);
    for(var i:int=0;i<9;i+=3){
    this["line"+i].addEventListener(MouseEvent.MOUSE_DOWN,downF);
    this["line"+i].ivar=i;
    function downF(e:MouseEvent):void{
    lineThickness=MovieClip(e.currentTarget).ivar;
    var colorA:Array=[[colorRed,0xff0000],[colorGreen,0x00ff00], ...,[colorBlack,0x000000]];
    for(i=0;i<colorA.length;i++){
    colorA[i][0].addEventListener(MouseEvent.MOUSE_DOWN,colorF);
    colorA[i][0].ivar=i;
    function colorF(e:MouseEvent):void{
    selectedColor=MovieClip(e.currentTarget).ivar;
    erase_btn.addEventListener(MouseEvent.MOUSE_DOWN,eraseF);
    function eraseF(e:MouseEvent):void{
    this.graphics.clear();
    Mar 8, 2013 8:02 PM   in reply to kglad
    Thank you for the example. I have also tried implementing this, not sure if Weston got what he needed.
    I have: iMac OS X.7.5   2.7GHz i5, 8GB ram - CS6 targeting iOS & Android 3.4 or 3.6 SDK
    I am looking to impliment a simple drawing function. The above looks good and simple to me (not that I understand each process).
    I tried a new AS3 layout, added some buttons represented by the colorGreen etc...
    When selecting a colour button, without having drawn, I get an error: ArgumentError: Error #1063: Argument count mismatch on kglad_fla::MainTimeline/startDrawing(). Expected 0, got 1.
    when attempting to draw:
    ArgumentError: Error #1063: Argument count mismatch on kglad_fla::MainTimeline/stopDrawing(). Expected 0, got 1.
    It starts off with this error:
    [SWF] kglad.swf - 83805 bytes after decompression
    TypeError: Error #1010: A term is undefined and has no properties.
              at kglad_fla::MainTimeline/frame1()[kglad_fla.MainTimeline::frame1:31]
              at runtime::ContentPlayer/loadInitialContent()
              at runtime::ContentPlayer/playRawContent()
              at runtime::ContentPlayer/playContent()
              at runtime::AppRunner/run()
              at ADLAppEntry/run()
              at global/runtime::ADLEntry()
    I tried setting the 'this.' to an 'mc.' instead, and while it alleviated the button error, it got me no further. Could I ask for assistance in getting this functional PLEASE...
    Could you explain to me: colorA[i][0]   (ahhh... found   http://active.tutsplus.com/tutorials/actionscript/as3-101-arrays/ ) another newbie...
    Mar 9, 2013 9:47 AM   in reply to amandasyd
    Change
    startDrawing()
    to
    startDrawing(e:MouseEvent=null)
    do the same thing with stopDrawing()
  • kglad
    Jul 21, 2002
    Mar 9, 2013 9:56 AM   in reply to kglad
    use:
    function startDrawing(e:MouseEvent):void {
              if (mouseX<455) {
    function drawLine(e:MouseEvent):void {
    function stopDrawing(e:MouseEvent):void {
    Mar 9, 2013 4:16 PM   in reply to kglad
    Thank you Amy and Mr K.
    Tried that, get an error from line 24
    23. for(var i:int=0;i<9;i+=3){
    24.      this["line"+i].addEventListener(MouseEvent.MOUSE_DOWN,downF);
    25.      this["line"+i].ivar=i;
    26. }
              at kgladD_fla::MainTimeline/frame1()[kgladD_fla.MainTimeline::frame1:24]
    Tried changing from iOS SDK 3.6 to to 3.4 and back to Flash11, made little difference except the way the error was handeled..
    In trying to follow through, I quoted out the to sections 23-26 and 32-36 (var colorA:Array=[[...)
    and notices the effects shown in the diagram
    Strange that the drawing functioned behind or on the button, went point to point between the movieclips... (set with instance names: colorRed, etc) but good to see something (anything) happening - As the mouse is dragged ove the exit button the same drawing pattern (as in/behind the erase button) is seen through the Exit button until the mouse exits that button. If I set the alpha of the colour MC's - you can see the same effect behind them...
    I'm obviously not seeting up the stage elements correctly - have the FLA at http://esdd.us/cs6/kglad.fla
    In anticipation, could the drawing be set on a clear "stage" above a background image or over a background image. Thank you for your time and assistance.
    Mar 9, 2013 4:19 PM   in reply to amandasyd
    If I set one MC in the background to cover the full stage - and reduce it's alph to 0 - then the drawing shows up on the whole stage.
  • kglad
    Jul 21, 2002
    Mar 9, 2013 4:31 PM   in reply to amandasyd
    you don't have one or more of line0,...,line8 defined.
    Mar 9, 2013 5:59 PM   in reply to kglad
    I probably don't have any defined, but I'll go looking and see what I can learn. Thank you.
  • kglad
    Jul 21, 2002
    Mar 9, 2013 8:11 PM   in reply to amandasyd
    you're welcome.
    line0 etc set the thickness of the drawn line.
    Mar 9, 2013 9:10 PM   in reply to amandasyd
    var line1:Shape = new Shape();
    2, 8, and also did line0...
    I wasn't sure if the index would start at 0 or 2 (i+=3) so the last one was suppose to be just incase, should have done a trace before showing how much I don't know.
    ReferenceError: Error #1056: Cannot create property ivar on flash.display.Shape.
              at kglad_fla::MainTimeline/frame1()[kglad_fla.MainTimeline::frame1:76]
    74. for(var i:int=0;i<9;i+=3){
    75.       this["line"+i].addEventListener(MouseEvent.MOUSE_DOWN,downF);
    76.      this["line"+i].ivar=i;
    77. }
    Any further assistance appreciated. Thank you
    Mar 9, 2013 9:34 PM   in reply to amandasyd
    Sorry Mr K, I didn't see the entry at 2:11 - must have already been on this page without refreshing.
  • kglad
    Jul 21, 2002
    Mar 10, 2013 7:12 AM   in reply to amandasyd
    those should be movieclips, not shapes.
    they need to be clickable and they should be on-stage.  they are controls that allow the user to control their drawing.
    if you don't want to allow that control, you don't need to use that part of the code.
    Mar 10, 2013 2:31 PM   in reply to kglad
    Thank you Sir... They were buttons and then back to movieclips when I was looking at the code nd it said:
          lineThickness = MovieClip(e.currentTarget).ivar;
    I also found some helpful info on: http://help.adobe.com/en_US/ActionScript/3.0_ProgrammingAS3/WS5b3ccc51 6d4fbf351e63e3d118a9b90204-7dd9.html
    It dates back to CS4 but assisted with concept. What I've done for the pallet is put an image of an artist pallet, and select colour from that.
    Thank you (and Amy) for your assistance.
  • kglad
    Jul 21, 2002
    Mar 12, 2013 7:53 AM   in reply to amandasyd
    you're welcome.
