Hi everyone,
I'm going thru and updating all our aging MX7 installs at work, with the latest hotfixes and patches.
That has all gone fine, but the two hotfixes that I need seems to no longer be available, and I am wondering if any of you have the files?
This is the link to hotfix I am after, specifically,
CVE-2009-1872 and CVE-2009-1877 Hotfix for ColdFusion 7.0.2
CVE-2009-1875 Hotfix for ColdFusion 7.0.2
http://www.adobe.com/support/security/bulletins/apsb09-12.html
The links for the hotfixes are not working.
http://download.macromedia.com/pub/coldfusion/updates/702/7_0_2.zip
http://download.macromedia.com/pub/coldfusion/updates/702/CF7.0.2.zip
Do any of you have zip files floating around, or is someone from Adobe able to fix the links?
I realise it's a very old hotfix, and support for it has probably stopped, but I figured I may as well try to find it
Thanks heaps.
Leith
Can Adobe investigate this?
I need this patch too. Adobe will you please make this patch availiable again? Thank you. If not this one then a replacement one that will fix the vulnerability.
Thank you for letting us know.
I am looking into this and will forward this to concern team.
Regards,
Priyank
Any word on this?
I need all the updates/hotfixes for MX7 please repair the broken links. Did anyone find the files? If so Please Please reply...
Any update on this?
Due to the lack of action / care by Adobe, I've had to find a way to mitigate this Cold Fusion security
issue (ie lack of the Cold Fusion Hotfix name: CVE-2009-1875).
Add the following to the Apache web server config:
<VirtualHost *:80>
<Directory /var/www/html>
AllowOverride AuthConfig Indexes Limit Options FileInfo
RewriteEngine on
RewriteCond %{REQUEST_URI} %\d\d
RewriteRule ^(.*)(%\d+)(.*)$ $1$3
</Directory>
</VirtualHost>
With this config in place, the following URL:
http://localhost/index%2500.cfm
Will redirect to:
Enjoy!
Thanks, Caleb. Unfortunately, our server is Windows-based. Do you happen to have a solution for that? 🙂
I don't I'm sorry
I'm Linux only...
