Importing illustrator pdfs into photoshop sometimes won't allow me to open and check resolution?
Nov 7, 2012 2:28 PM
Here's the scenario:
Customer sends me an illustrator file with an embedded image. I need to check the resolution of the image to see see if it is high resolution enough for print. I delete all art but the image in illustrator and then save that file as a pdf with the illustrator default.
I drag that pdf file into photoshop where I get the "Import PDF" dialog box. I know if I select the "Pages" button, then the resolution and color that appears in the dialog box are not the true specifications for the image. I have to select the "Images" button and open the file from there HOWEVER sometimes this option is not available and the "open" button is grayed out. I have yet to figure out why this happens on some of the pdf files I've saved from Illustrator.
This is the only way I have found to check resolutions on embedded files where I do not have the actual linked graphic. Does anyone have any ideas? Thanks for any help!
    Mar 26, 2013 11:31 AM   in reply to Rice14
    Just check the resolution in Illustrator instead of exporting a PDF to check in Photoshop.
    If the image only is selected then the resolution is displayed in Control bar.
    It may be in a nest of groups so either double-click repeatedly on the image until you've drilled down to it or select it in the Layers panel where the disclosure triangles will give access to it.
    Mar 26, 2013 11:46 AM   in reply to Rice14
    Sorry for not noticing this thread back in November.
