ALIREZA S.
Sound looping using Swiffy export to HTML5
Nov 10, 2012 6:06 AM
Tags: #flash #export #sound #to #loop #html5 #swiffy
I am facing a problem when I export my flash using Google SWIFFY to HTML5!
It wont play my sound track layer as loop anymore. only play it once when luanching the page in HTML5 and then it stops!
I changed the settings in my Flash sound properties from Start to Event , from Repeat to Loop etc. but still not a change in exported result, can you advise me how can I get this soundtrack works as loop when I export it using Swiffy? Thanks a lot.
Ali
  • kglad
    Jul 21, 2002
    Nov 10, 2012 12:08 PM   in reply to ALIREZA S.
    assign the sound's sync property to stream and replay/loop the timeline that contains the sound.
    Jun 19, 2013 6:24 AM   in reply to kglad
    Just in case anyone else comes looking into this issue....
    I quote the warning message after exporting a flash file:
    Swiffy Flash Extension for Win v1.1.1 [Swiffy v5.2.0]
    - Warnings -
    Streaming audio is not supported.
    The only solution I've found is to copy and paste the (event) sound keyframe as many times as needed along the timeline, and set repeat/loop to 1. On-the-beat replay not guaranteed.
    The swiffy documentation:
    https://www.google.com/doubleclick/studio/swiffy/gettingstarted.html
    ...says sound is "partially supported", and then only by Chrome,  Safari, IE9 and Opera (no sound at all in FF).
    So far, testing, IE9 doesn't play loops, but maybe Chrome will (later, at home).
    Jun 19, 2013 11:28 PM   in reply to tweenTeen
    Chrome doesn't loop either
