Dhdut
JPG files are being erased by PE 5 Organizer
Nov 11, 2012 7:31 AM
I have experienced a weird incident with Photoshop Element 5.0, to which I
couldn't believe until I could reproduce it: *the PE Organizer erases all
*.JPG files in the pictures' directory I am working on when closing under
certain conditions.* You will find in appendix the report of the tests I
have been running.
The procedure that leads to files being deleted is the following:
- Initial state: PE 5.0 Editor and Organizer inactive. The directory
contains 2 JPG files (IMG_0177a.JPG). The files in the directory are sorted
by file type.
1. Open PE 5.0 Organizer.
2. Select picture IMG_0022.CR2.
files.
4. Save the file after edit as IMG_0022.DNG. The directory still contains
the 2 .jpg files.
5. Click on "Open image".  The directory still contains the 2 .jpg files.
files.
files.
8. Click onto the Organizer window to give it the focus. The directory
still contains the 3 .jpg files.
9. Close the Organizer. The 3 .jpg files are no longer in the directory.
The appendix shows more details (screenshots) of my tests (see tests 1 and
3).
I couldn't find any configuration in PE that can cause this behaviour. I
could also find no mention of it on your support site. Could you please
help me?
- Is that behaviour made possible through a configuration preference or is
it a known bug?
- If it is a bug, is there a fix for it?
- If not, how else can I avoid such deletions?
- If I store the .JPG files in a subdirectory of that where the raw photo
files are stored, can I be sure that the JPG files will never be erased
through that behaviour?
I have just experienced that incident only this fall because I have just
installed PE 5.0 and started processing raw photo files recently (I had PE
4 up to then).
My configuration:
- PC with Windows XP Pro SP3 and all updates installed. 1.5 GB RAM. Drive
C: is 37 GB, free space is 13 GB.
- I got PE 5.0.2 with my Canon camera I bought in January 2008. I installed
the update in August 2012. No add-on SW has been installed to PE.
- I store my photo files on a NAS disk (La Cie 1 TB, free space: 203 GB)
and use another NAS disk for backup copies (that backup disk is only
running for backups; it was never running when I experienced the incident
below).
- My photo files are stored in directories organized by date and event. Up
to now, I have been storing all types of photo files in one directory per
event (.CR2, .JPG, .DNG).
Best regards
Dominique
    Nov 11, 2012 8:53 AM   in reply to Dhdut
    I have tried to reproduce your problem without success. The files are still there and visible in Explorer or Organizer folder view.
    My configuration is very similar, PSE5.02 on Win XP SP3, Adobe Camera raw 3.5. I put 2 jpegs and one .CR2 file (Canon 20D). However I don't use a NAS drive.
    Are the missing file in the waste basket ?
    Note that you are not speaking to Adobe here, it's a user to user forum. Anyway, Adobe will support only the most recent versions of Elements.
    Nov 22, 2012 12:28 AM   in reply to Dhdut
    Not sure why this is happening this way but may be closing PSE processes which access and work upon files in the background might make a difference.
    Please launch Organizer and click Edit >> Preferences >> Media Analysis and turn off all checkboxes.
    From the task manager, kill the following exes if running-
    ElementsAutoAnalyzer
    Adobe Photoshop File Agent
    Dynamic Link Manager
    repeat your workflow and check if the issue still happens.
    Andaleeb
