I would suggest that a new discussion of Performance Issues be started under the above heading. The existing thread "Experienceing performance related issues in Lightroom 4.X" is historic for all entents and purposes.
What I still see in 4.3RC1 is confusing as ever.
OS X 10.8.2
MacBook Pro (15 inch retina)
2.6 GHz, quad-core i7
8 GB RAM
512 GB SSD
Nikon D800 NEF files (~32.5 MB, 7360 x 4912 pixels)
All 1:1 previews calculated before any "measurements". Times (as shown in the Acvity Monitor application) are from the start of any CPU activity until activity ceases. Zoom to 1:1 several times at each stage in order to populate any caches.
Library Loupe view
zoom to 1: ~7 1/2 sec
Library Grid view
zoom to 1: ~4 sec
Why is this operation faster from Grid view?
Develop
zoom to 1:1 ~1 sec
Why is this ooperation faster in the Develop module than in the Library module?
Done. Here is the link.
http://feedback.photoshop.com/photoshop_family/topics/lr4_3_slow_in_de velop_mode
It looks to me like it is always redoing the 1:1 jpeg preview in Library even if you already have it. If you already have the 1:1 rendered it should just use that but for whatever reason it doesn't. In Develop the zoom is fast because it only has to create the preview for the area you see in the viewport. I.e. it only renders a small subsection of the raw file which it should be able to do in subsecond time on this machine. Rendering an entire D800 raw file at 1:1 is of course a much more lengthy operation.
ISeward wrote:
I think I have seen a post from someone who works for Adobe (Victoria Brampton?) which seemed to indicate that the problem is the Retina display - the Macbook just can't move the pixels quickly enough.
I suggest you check the source of your information.
The MacBook Pro easily moves those pixels around when zooming in Photoshop CS5.
Bob,
I just tried it on my 15" MBP retina and there is no difference between zooming from the grid view or zooming from the Loupe view. This is with 1:1 previews generated. It takes about 1 to two seconds to zoom regardless how or where I do it. The only difference is that from the Loupe view it does the zoom animation, while from grid view when clicking 1:1 it goes through black. The raw files are 14-bit nefs from a D600, so even though not a D800, quite large too. The catalog and previews for these files is on the SSD drive. The nefs are on a USB 3.0 external disk. If I delete the 1:1 previews I get longer times for zooming because it needs to generate the 1:1 previews I am guessing, but only the first time I zoom.
The machine is a 2.3 GHz Intel Core i7, 16GB memory. Running 10.8.2. This is a quad core with 8 logical processors identified in System Info in Lightroom. I also noticed that Lightroom now shows that Camera Raw will only use 4 threads on this machine, probably to avoid hyperthreading.
Don't know why there is a difference with your machine.
It is a complete myth that the MBPr cannot move those pixels around. The display card is more than fast enough and it easily plays 1080p HD video, animates 3D stuff and much more. The number of pixels on the display is basically the same as on a 30" display. That is really nothing special for the display card at all. Before this, I was using Lightroom on a 30" display from a previous generation MacBook Air. That was only a C2D machine with intel graphics. It works just fine in Lightroom 3 and 4.
The machine can sometimes show tearing when you switch back and forth between battery power and power adaptor (bump the MagSafe adapator by accident). This switches beteen intel graphics and the NVIDIA card in the default setting (I turn the automatic switching off for this reason in the Energy Saver control panel). However in Lightroom there is no effect as it doesn't really use any hardware acceleration.
Jao vdL wrote:
Bob,
Many, many, thanks for taking the time to look into this, Jao.
I have been systemattically removing a lot of applications and utilities but, so far at least, nothing changes my situation.
I am at a complete loss to explain what the hell is going on my computer.
I'm open to any suggestions regarding how to figure out what is going on.
That's all for this evening ![]()
Rob Cole wrote:
I assume you already tried deleting the .lrdata folder (please forgive if this has already been stated).
The last thing I tried last night was:
(1) write xmp to disk
(2) remove all images from the test catalog
(3) delete the .lrdata file
(4) delete the .lrcat file
(4) create a new catalog containing 7, D800 NEF files
(5) generate all previews (1:1 previews are 2048 pixels)
The problem is exactly the same as before. ![]()
North America
Asia Pacific
