vid2164
Can anyone tell what this means; Error: Error #2069: The Loader class does not implement this method
Nov 11, 2012 4:06 PM
I can't figure out what the problem is with this,Error message showing up on the Output tab in Flash Professional CS5.5 Error #2069: The Loaderclass does not implement this method. at Error$/throwError() at flash. display::Loader/addChild() at Untitled_fla:: MainTimeline/frame 1() Please keep in mind that I'm new to Flash, and extreamly new to Action Scripting.
    Nov 14, 2012 2:30 AM   in reply to vid2164
    Moving this thread to the Flash Pro - General forum.
    Nov 14, 2012 5:02 AM   in reply to vid2164
    You will need to show the code that is related to using the Loader class.  The error is indicating an attempt to use a method for the Loader that is not a Loader class method.  You should also go into your Flash Publish Settings and select the option to Permit Debugging... it could add a line number to the error message to help narrow down the suspects.
