Ricedoro
JVC camcorders
Nov 12, 2012 4:11 AM
Free trial doesn't seem to recognize JVC GZ-E205 camcorder. Any obvioous solution?
    Nov 12, 2012 4:15 AM   in reply to Ricedoro
    The trial of what product on what system? In any case, you better ask such specific questions in teh relevant product forum.
    Mylenium
    Nov 12, 2012 10:56 AM   in reply to Ricedoro
    Moving this discussion to the Premiere Elements forum.
    Nov 12, 2012 12:50 PM   in reply to Ricedoro
    What connection does that camcorder use?
    Cheers,
    Neale
    Nov 12, 2012 12:53 PM   in reply to Ricedoro
    It looks like your camera shoots HD as AVCHD, which will work just fine in PrE 11, per this review: http://www.trustedreviews.com/jvc-hd-everio-gz-e205_Camcorder_review
    All you will need to do is Copy over the camera's SD card's full folder structure to your computer, and then Import the media files (be sure to Copy the full folder structure).
    Good luck, and hope that helps,
    Nov 12, 2012 2:56 PM   in reply to Ricedoro
    This is why you copy the full folder structure to your hard drive
    Metadata contained in folder http://forums.adobe.com/thread/1015001?tstart=0
    Nov 15, 2012 8:48 AM   in reply to Ricedoro
    A camera is just another USB device, like an external hard drive or a "thumb drive" memory stick
    If you don't "see" the camera with Windows Explorer, you have a hardware problem, or a bad USB cable
    Nov 15, 2012 9:28 AM   in reply to Ricedoro
    For the camera to act like a HDD, you will need to both turn it ON (assume that you have done that), and also set its Mode. The name of that Mode differs camera mfgr. to camera mfgr., but you manual will tell you what that name is, and also how to set it. Have you set the Mode appropriately?
    If so, when you turn the camera ON, and it is hooked up to the computer, do you not get the Windows "bing-bong?"
    If not, there are several possibilities:
    The cable is bad
    The connector on the camera is bad
    The connector on the computer is bad
    The USB controller chip on the MoBo is bad
    The USB driver in the OS is not correct
    Good luck, and as John T. says, I woud try a different USB cable (cheap fix) first.
