i have tried it.There is a RichEditableText component in the TextInput skin:
<s:RichEditableText id="textDisplay"
verticalAlign="middle"
widthInChars="10"
left="35" right="1" top="1" bottom="1" />
i defined a searchIcon and an Image component in the skin:
[Embed(source="libs/new_search_left.png",scaleGridTop="1", scaleGridBottom="13",scaleGridLeft="1", scaleGridRight="41")]
[Bindable]
public var searchIcon:Class;
<s:Image source="{searchIcon}" />
the problem is that i was unable to control the input cursor.
at the same time the width and height of the TextInput component seem out of expect.
plz help...
thanks for your replies.Below is my code.Waiting for your help...
----------------------------MyView.xml-----------------------------
<s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark">
<fx:Declarations>
<!-- 将非可视元素(例如服务、值对象)放在此处 -->
</fx:Declarations>
<s:HGroup width="100%" id="testgp" horizontalAlign="center" verticalAlign="middle"
paddingTop="10" paddingLeft="10" paddingRight="10" paddingBottom="10">
<s:TextInput width="80%" id="input" skinClass="skin.SeTextInputSkin"/>
<s:Button width="20%" label="search" />
</s:HGroup>
</s:View>
----------------------------SeTextInputSkin.xml----------------------- ------
ADOBE SYSTEMS INCORPORATED
Copyright 2008 Adobe Systems Incorporated
All Rights Reserved.
NOTICE: Adobe permits you to use, modify, and distribute this file
in accordance with the terms of the license agreement accompanying it.
<!--- The default skin class for Spark TextInput component.
@see spark.components.TextInput
@langversion 3.0
@playerversion Flash 10
@playerversion AIR 1.5
@productversion Flex 4
<s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:fb="http://ns.adobe.com/flashbuilder/2009"
alpha.disabledStates="0.5" blendMode="normal">
<fx:Metadata>
<![CDATA[
* @copy spark.skins.spark.ApplicationSkin#hostComponent
[HostComponent("spark.components.TextInput")]
</fx:Metadata>
<fx:Script fb:purpose="styling">
<![CDATA[
import mx.core.FlexVersion;
private var paddingChanged:Boolean;
/* Define the skin elements that should not be colorized. */
static private const exclusions:Array = ["background", "textDisplay", "promptDisplay", "border"];
/* exclusions before Flex 4.5 for backwards-compatibility purposes */
static private const exclusions_4_0:Array = ["background", "textDisplay", "promptDisplay"];
* @private
override public function get colorizeExclusions():Array
// Since border is styleable via borderColor, no need to allow chromeColor to affect
// the border. This is wrapped in a compatibility flag since this change was added
// in Flex 4.5
if (FlexVersion.compatibilityVersion < FlexVersion.VERSION_4_5)
return exclusions_4_0;
return exclusions;
/* Define the content fill items that should be colored by the "contentBackgroundColor" style. */
static private const contentFill:Array = ["bgFill"];
* @private
override public function get contentItems():Array {return contentFill};
* @private
override protected function commitProperties():void
super.commitProperties();
if (paddingChanged)
updatePadding();
paddingChanged = false;
* @private
override protected function initializationComplete():void
useChromeColor = true;
super.initializationComplete();
* @private
override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
if (getStyle("borderVisible") == true)
border.visible = true;
shadow.visible = true;
background.left = background.top = background.right = background.bottom = 1;
textDisplay.left = textDisplay.top = textDisplay.right = textDisplay.bottom = 1;
if (promptDisplay)
promptDisplay.setLayoutBoundsSize(unscaledWidth - 2, unscaledHeight - 2);
promptDisplay.setLayoutBoundsPosition(1, 1);
else
border.visible = false;
shadow.visible = false;
background.left = background.top = background.right = background.bottom = 0;
textDisplay.left = textDisplay.top = textDisplay.right = textDisplay.bottom = 0;
if (promptDisplay)
promptDisplay.setLayoutBoundsSize(unscaledWidth, unscaledHeight);
promptDisplay.setLayoutBoundsPosition(0, 0);
borderStroke.color = getStyle("borderColor");
borderStroke.alpha = getStyle("borderAlpha");
super.updateDisplayList(unscaledWidth, unscaledHeight);
* @private
private function updatePadding():void
if (!textDisplay)
return;
// Push padding styles into the textDisplay
var padding:Number;
padding = getStyle("paddingLeft");
if (textDisplay.getStyle("paddingLeft") != padding)
textDisplay.setStyle("paddingLeft", padding);
padding = getStyle("paddingTop");
if (textDisplay.getStyle("paddingTop") != padding)
textDisplay.setStyle("paddingTop", padding);
padding = getStyle("paddingRight");
if (textDisplay.getStyle("paddingRight") != padding)
textDisplay.setStyle("paddingRight", padding);
padding = getStyle("paddingBottom");
if (textDisplay.getStyle("paddingBottom") != padding)
textDisplay.setStyle("paddingBottom", padding);
if (!promptDisplay)
return;
if (promptDisplay.getStyle("paddingLeft") != padding)
promptDisplay.setStyle("paddingLeft", padding);
if (promptDisplay.getStyle("paddingTop") != padding)
promptDisplay.setStyle("paddingTop", padding);
if (promptDisplay.getStyle("paddingRight") != padding)
promptDisplay.setStyle("paddingRight", padding);
if (promptDisplay.getStyle("paddingBottom") != padding)
promptDisplay.setStyle("paddingBottom", padding);
* @private
override public function styleChanged(styleProp:String):void
var allStyles:Boolean = !styleProp || styleProp == "styleName";
super.styleChanged(styleProp);
if (allStyles || styleProp.indexOf("padding") == 0)
paddingChanged = true;
invalidateProperties();
</fx:Script>
<fx:Script>
<![CDATA[
* @private
private static const focusExclusions:Array = ["textDisplay"];
* @private
override public function get focusSkinExclusions():Array { return focusExclusions;};
</fx:Script>
<fx:Script>
<![CDATA[
[Bindable]
</fx:Script>
<s:states>
<s:State name="normal"/>
<s:State name="disabled" stateGroups="disabledStates"/>
<s:State name="normalWithPrompt"/>
<s:State name="disabledWithPrompt" stateGroups="disabledStates"/>
</s:states>
<!-- border -->
<!--- @private -->
<s:Rect left="0" right="0" top="0" bottom="0" id="border">
<s:stroke>
<!--- @private -->
<s:SolidColorStroke id="borderStroke" weight="1" />
</s:stroke>
</s:Rect>
<!-- fill -->
<!--- Defines the appearance of the TextInput component's background. -->
<s:Rect id="background" left="1" right="1" top="1" bottom="1">
<s:fill>
<!--- @private Defines the background fill color. -->
<s:SolidColor id="bgFill" color="0xFFFFFF" />
</s:fill>
</s:Rect>
<!-- shadow -->
<!--- @private -->
<s:Rect left="1" top="1" right="1" height="1" id="shadow">
<s:fill>
<s:SolidColor color="0x000000" alpha="0.12" />
</s:fill>
</s:Rect>
<!-- text -->
<!--- @copy spark.components.supportClasses.SkinnableTextBase#textDisplay -->
widthInChars="10"
left="1" right="1" top="1" bottom="1" />
<s:Image source="{searchIcon}" smooth="true"/>
<!--- Defines the Label that is used for prompt text. The includeInLayout property is false so the prompt text does not affect measurement. -->
<s:Label id="promptDisplay" maxDisplayedLines="1"
mouseEnabled="false" mouseChildren="false"
includeIn="normalWithPrompt,disabledWithPrompt"
includeInLayout="false"
</s:SparkSkin>
North America
Asia Pacific
