Camelino1
Adobe Photoshop Elements 11 - open .eps files?
Nov 13, 2012 4:26 AM
Tags: #photoshop #adobe #elements #open #eps #11
Can it be that Adobe Photoshop Elements can open 11 no. Eps files? This worked before but?
If that is so, why is not it? Is there an alternative?
    Nov 13, 2012 4:30 AM   in reply to Camelino1
    Alternatives whould be any tool that can use GhostScript, including GIMP, Inkscape or free image viewers liek IrfanView. The rest is a bit vague, since you did not provide any system info or otehr details, but I would guess that since EPS files are only used in professional environments, PSE never truly supported them fully in the first place...
    Mylenium
    Nov 13, 2012 10:15 AM   in reply to Mylenium
    Moving this discussion to the Photoshop Elements forum.
    Nov 13, 2012 11:26 AM   in reply to Camelino1
    http://helpx.adobe.com/photoshop-elements/kb/supported-file-formats-pr emiere-elements.html
    The only thing which puzzles me is that PSE11 still includes the eps patterns...
    I also think that the best format for Elements to open files created by vector drawing softwares like Illustrator is the PDF format. I suppose most of those softwares can export PDF file. If they can't, there is always the possibility to use virtual printer drivers where you 'print' to a pdf file (GhostScript, as cited by Mylenium).
    Jan 6, 2013 9:17 PM   in reply to MichelBParis
    The link provided above includes EPS files in the list of supported Elements files (for importing).
    Any explanation?
    http://helpx.adobe.com/photoshop-elements/kb/supported-file-formats-pr emiere-elements.html#main_Adobe_Photoshop_Elements___File_formats_for_ importing)
    Mar 4, 2013 3:45 AM   in reply to DaveEbenhoh
    Here is how you can open EPS file in Elements 11 (with a workaround) http://forums.adobe.com/message/4920543#4920543
    Mar 5, 2013 12:43 AM   in reply to ukgaurav
    Here is blog post explaining how to open EPS files in PSE11 with a workaround - http://blogs.adobe.com/pselements/open-eps-files-in-photoshop-elements -11/
    Garry
    Mar 5, 2013 1:37 AM   in reply to ukgaurav
    I just feel i should comment and say if one opens an eps with a tiff preview with File>Open As>Tiff, then all one gets in pse 11 is the 8 bit preview file and not the real fullsize eps.
    And the workaround by putting the EPS Parser.8BY plugin from an older version of photoshop elements doesn't help those who don't have an older version of photoshop elements.
    (yes people have a choice to buy pse 11 or not, but since adobe doesn't offer older versions, then people will still buy it)
    I think a majority of people want to open vector files saved from illustrator that are not in the pdf format, in which there thousands of those on the web for download.
    (as an example pse 11 ships with some postscript patterns inside the patterns folder, but one can't open them in pse 11)
    I would like to suggest making the plugin available for those that don't have an older version of elements to get the EPS Parser.8BY from.
    Mar 5, 2013 1:51 AM   in reply to R_Kelly
    Don't forget there are many free (and excellent) softwares to do the conversion ; I am using Faststone myself.
    Agreed. It could be supplied in the 'optional' plugins folder.
    Mar 5, 2013 2:43 AM   in reply to MichelBParis
    Thank you guys for sharing your feedback. Will share this with respective folks.
    Jun 8, 2013 1:17 PM   in reply to ukgaurav
    Here's some sample eps files that a user would not be able to open in pse 11:
    http://people.sc.fsu.edu/~jburkardt/data/eps/eps.html
    This sample eps does have a tiff preview, but as you can see the tiff preview is clearly inferior to the real eps
    that would open in an older version of pse.
    http://www.fastcars.com.au/section/downloads/1113--eps-sample
