FM10 unstructured, Windows 7 64-bit, working with documents I inherited in which a Zapf Dingbats character tag was used for bullets in paragraph tags.
Opening one of those documents gives the message, "The 'Zapfdingbats' Font is not available. It will be replaced by 'AdobePiStd'." Bullets appear as question marks.
ZapfDingbats BT is installed and appears in the FM font menus. If I change the Bullet character tag from Adobe Pi Std to ZapfDingbats BT, the bullets look right.
The conversion is set in maker.ini as follows:
Zapfdingbats, *,*= Adobe Pi Std,*,*
I tried deleting that line, had no effect. I tried replacing it with the following, had no effect:
Zapfdingbats, *,*= ZapfDingbats BT,*,*
Is there some system-level way to fix this? It would be annoying to have to update the style in every document.
I haven't tried it, but I think that should be:
Zapfdingbats, *, *, *= ZapfDingbats BT, *, *, *
And be sure it is in the Re: Zapf Dingbats bad font replacement in FM10 section, not
Re: Zapf Dingbats bad font replacement in FM10 section.
> Zapfdingbats, ,= ZapfDingbats BT,,
I forgot to mention that, starting with FM10, you can do font
replacement easily. Open the Fonts pod, click the missing ZapfDingbats
font and then click the Replace button. The Fonts Replace pod will open
and you will be able to specify the BT version of the font as a
permanent replacement. Of course, that assumes you aren't trading the
file back to someone who wants it to continue to use the original font.
> If I have to do that, I'll edit the styles to use the bullet characters in the bullet paragraph tags' font and purge all use of dingbat fonts.
If these documents ever need to be opened in an FM version earlier than 8.0, using native bullets probably won't work, as they will probably be Unicode (UTF8) code points that will be treated as three nearly random characters.
I'd suggest instead converting all instances to a Variable, so that managing them can be done in one place per document.
On a legacy platform:
Var Name: char.dingbat.bullet
Var Def: <Dingbat>\xc6
Char Fmt: Dingbat is defined to be font family Zaph Dingbats
On a Unicode platform:
Var Def: <Dingbat>\u2022
Char Fmt: Dingbat is defined to be any font family that has code point 2022 populated, perhaps even just set to "As Is".
Dang. Once again, the forum software scrambled my post. Let's try again. Here's a repost:
And be sure it is in the [UnknownToKnownFontMap] section, not [WindowsToFrameFontAliases] section.
I couldn't get font substitution to work, so I just hacked Adobe Pi Std with Type Light to add the bullet glyphs and map them to l and n. Didn't work until I figured out I needed to reboot Windows to apply the font change.
Still not working, but it's no longer a font substitution issue so I'll start another thread.
That worked, thanks. I installed a Type 1 copy of Zapf Dingbats from an Illustrator 7 CD-ROM, commented out the substitution, replaced the hacked font, deleted .font_cache, rebooted, and it's working fine.
And I guess the fundamental problem was that the documentation department's master font directory contained only the .pfm, not the .pfb.
North America
Asia Pacific
