Unknown error: [UNKN] - Illustrator cs6
Nov 13, 2012 10:46 PM
Tags: ##adobe ##cs6 ##error ##mac ##unknown ##illustrator ##size
I'm a Illustrator cs6 user, and the last days, I'm getting this error when I'm saving some files...
The file seems to be ok, I didn't find yet what this error does especifically, but the MB size turns bigger than a regular/similar file without the error.
Then, I tried to start again from zero, and when I finally rebuild the files, I get that error again at the end. Could you explain me the meaning of that error and how to fix it? - even if I have to fix it by code ?-. I didn't find useful information with a regular google search.
Thank you very much for your answer.
    Nov 14, 2012 1:55 AM   in reply to Hans Patricio
    Have you checked your disk for hardware errors?
    Nov 14, 2012 6:45 AM   in reply to Hans Patricio
    What's in the file and which options do you choose when saving?
    Do you save an .AI? Could you turn "compression" off?
    Nov 14, 2012 7:32 AM   in reply to Hans Patricio
    If you can copy the error to other files, then please check, if you've got this problem described here: http://forums.adobe.com/thread/713466
    Nov 14, 2012 8:02 AM   in reply to Hans Patricio
    Illustrator now does contain mechanism to solve the HUH error, so it might of course give other error codes. In order to have this symptom you do not need to use brushes yourself, that's the danger of the HUH error.
