Pixelated PSD
Nov 13, 2012 11:20 PM
Hello all,
      currently i'm having this problem of a logo that i would like to put in my video went pixelted after i scaled it down, a problem that usually happened when i scaled up an image but not when i scaled it down. i've tried both PNG and PSD file format and the result is still pixelated, even in project.
    Nov 14, 2012 6:56 AM   in reply to Zaxxshoxx
    What are the Premiere Sequence settings (video format), and what are the dimensions of the graphic file? Are you scaling the graphic in PS or Pr? In Premiere Program Monitor window, is quality set to FULL? Right-click in there and check
    Jeff
    Nov 19, 2012 5:29 PM   in reply to Zaxxshoxx
    Post a screen grab, so we can see the bad logo.
    Nov 19, 2012 11:10 PM   in reply to Zaxxshoxx
    Your program monitor is set to "Fit". Change it to 100% and then see how you feel about it.
    Nov 20, 2012 9:12 AM   in reply to Zaxxshoxx
    You cannot judge the quality of the image using the PP built-in monitors.  They are not designed to show you an accurate image.  You need to either hook up and calibrate a real TV to your computer for proper monitoring, or you need to export and take that to a real TV, properly calibrated.  Until that's done, there's no way to know if you actually have an issue here.
