paperdeerphoto_2012
photos import into LR3 super contrasty, orange and with a Vignette
Nov 14, 2012 9:33 AM
Tags: #problem #color #raw #import #canon #lr3 #lightroom3 #5d #mii
My husband wiped off our wireless keyboard while LR3 was open, a bunch of settings windows popped up and now when I import photos they look ok and then when I click on them in develope mode they load and turn super dark, contrasty, orange and with a dark vignette (without touching any settings) Now, LR3 has always colour corrected a slight amount but this is  extreme...can anyone help me out?
    Nov 14, 2012 9:42 AM   in reply to paperdeerphoto_2012
    At some point the adjustments for one of your images was likely saved as the Default State for all images. On import this is being now be applied to every photo.
    To reset go to: Preferences>Presets> Default Develop Settings and press the [Reset all default Develop settings] key to restore a more neutral starting position.
    Nov 14, 2012 9:54 AM   in reply to paperdeerphoto_2012
    Next step, load your Import dialog.
    In the Import Dialog look at the Apply During Import panel and see if there is a preset listed in the Develop Settings pulldown. If so, clear it.
    Nov 14, 2012 11:22 AM   in reply to paperdeerphoto_2012
    Reuploaded? Can you give me more details as to what Reuploaded means?
    Nov 14, 2012 1:43 PM   in reply to paperdeerphoto_2012
    Let's take a different tack on this.  Your second import of the image muddies the waters slightly. (Generally a reimport is never a good solution)
    If you click the [Reset] button in Develop what happens?
    then
    If you apply the Preset: Lightroom General Presets>Zeroed what happens?
    Nov 14, 2012 2:43 PM   in reply to paperdeerphoto_2012
    Interesting:
    What do you have checked on this screen?
    What is the position of this switch?
    Nov 14, 2012 3:19 PM   in reply to paperdeerphoto_2012
    Make absolutely sure no default settings are being applied. Check that all develop settings are default and zero for most of them.
    From left field. How are you calibrating your monitor? This weird orange image problem can also be a consequence of a bad monitor profile.
    Nov 14, 2012 3:28 PM   in reply to Jao vdL
    I agree, Monitor profile is the next place to check in.
    Nov 14, 2012 4:07 PM   in reply to paperdeerphoto_2012
    ARe you calibrating? If not, if you are on windows, go into the monitor's properties pane and delete any icc profile associated with the monitor. This will likely fix the problem. What you describe is very typical for a bad monitor profile.
    Nov 14, 2012 4:12 PM   in reply to paperdeerphoto_2012
    OK then it is unlikely that it is a monitor profile issue. That is typical
    for windows machines. You should still be calibrating using a hardware
    calibrator though. What must be happening is that some default setting is
    being applied. Go into the menu Lightroom->Preferences->presets and hit the
    "reset all default develop settings" then in the import dialog, make sure
    you have no preset selected.
    On Wed, Nov 14, 2012 at 5:08 PM, paperdeerphoto_2012 <
    Nov 14, 2012 4:34 PM   in reply to paperdeerphoto_2012
    Ow! That is not good. For your 5D mk II, you should see a list of profiles like Adobe Default, Camera Standard, Camera Portrait, etc if you are looking at raw files. They somehow got wiped. You should probably reinstall Lightroom to get them back.
    Nov 14, 2012 4:42 PM   in reply to paperdeerphoto_2012
    No
    On Wed, Nov 14, 2012 at 5:39 PM, paperdeerphoto_2012 <
    Nov 14, 2012 4:48 PM   in reply to paperdeerphoto_2012
    No need to trash it. Just run the installer (the latest LR 3 can be
    downloaded from adobe if you need to) and it will overwrite the old binary
    and reinstall the support files. It should not overwrite your catalog nor
    even your preferences.
    On Wed, Nov 14, 2012 at 5:43 PM, paperdeerphoto_2012 <
    Nov 14, 2012 5:33 PM   in reply to paperdeerphoto_2012
    It should now always do Adobe standard except when you specifically change
    the default.
    On Wed, Nov 14, 2012 at 6:19 PM, paperdeerphoto_2012 <
