Adding a CFCASE to a Coldfusion SELECT dropdown
Nov 15, 2012 3:06 PM
I have the following simple dropdown on my form:
                          <select name="ttTo" id="ttTo" >
                            <option value="">Choose One</option>
                            <cfoutput query="rsTicketTo">
                              <option value="#rsTicketTo.ttEmail#">#rsTicketTo.ttDesc#</option>
                            </cfoutput>
                          </select>
                        </div>
How would I change my select above to include the sample functionality below but using ColdFusion?
Note: The #TicketType# variable below will be on the page but not from the same table as the ttTo value.
       // Check where to send support request to...
       switch (trim($fTicketTo))
       case "":
$error = 1;
$tMessage = "You must select a valid Recipient!";
break;
       case "Service":
if ($fTicketType == "T1")
$fTicketTo = 'serv1@xyz.com';
else
$fTicketTo = 'serv2@xyz.com';
break;
       case "Outage":
break;
       case "Data":
$fTicketTo = 'data@xyz.com';
break;
       case "Voice":
$fTicketTo = 'voice@xyz.com';
break;
       case "T1":
$fTicketTo = 't1@xyz.com';
break;
       case "Wire":
$fTicketTo = 'wire@xyz.com';
break;
       case "Phone":
$fTicketTo = 'pst@xyz.com';
break;
       case "Prov":
$fTicketTo = 'prov@xyz.com';
break;
       case "Cust":
$fTicketTo = 'cc@xyz.com';
break;
    Nov 15, 2012 7:03 PM   in reply to jlig
    Using switch/case inside a select control doesn't make any sense.  What are you hoping to accomplish?
    Nov 16, 2012 12:32 AM   in reply to jlig
    It isn't clear which query column corresponds to the case values 'service', 'outage', 'data', etc. There are also inconsistenties. You have defined the cases as subsequent values of trim($fTicketTo). Yet, within each case block, you again define a new variable of the same name ($fTicketTo). Another inconsistency is that "T1" is at once a value for $fTicketType and for trim($fTicketTo).
    If all you wished to do is to convert the given switch-case into a select-box, then you could proceed as follows:
    <cfform>
    <cfselect name="ttTo" id="ttTo" required="yes" message="You must select a valid Recipient!">
    <option value="">Choose support request</option>
    <option value="serv1@xyz.com">T1 Service</option>
    <option value="serv2@xyz.com">Service(except T1)</option>
    <option value="serv1@xyz.com">Outage</option>
    <option value="data@xyz.com">Data</option>
    <option value="voice@xyz.com">Voice</option>
    <option value="t1@xyz.com">T1</option>
    <option value="wire@xyz.com">Wire</option>
    <option value="pst@xyz.com">Phone</option>
    <option value="prov@xyz.com">Prov</option>
    <option value="cc@xyz.com">Cust</option>
    </cfselect>
    <cfinput name="sbmt" type="submit" value="Submit">
    </cfform>
    Nov 16, 2012 2:33 AM   in reply to jlig
    In that case, my first choice would be to use the case construct in the actual query to get the appropriate email address.
    Nov 16, 2012 8:35 AM   in reply to jlig
    There are a few of ways to do it.
    One is to set up cascading selects bound to cfc's.  If you choose this option, you use your cfc to pass the correct email to the second select.
    Another is to figure out the correct email with coldfusion code once the form has been submitted.  This would be my preference.
    Another is to use javascript to look at the values of the two selects and put the email address into a hidden field.
    Nov 19, 2012 7:13 AM   in reply to jlig
    <cfform>
    <cfif $fTicketType EQ "T1">
        <option value="serv1@xyz.com">Service</option>
    <cfelse>
        <option value="serv2@xyz.com">Service</option>
    </cfif>
    </cfselect>
    </cfform>
    Nov 19, 2012 1:36 PM   in reply to jlig
    In my opinion, all the preconditions you're setting make the issue unnecessarily complex. The values are coming in via a form, so you cannot avoid the effects of user-input. That said, the following is consistent with what you already have
    <cfquery datasource="care" result="insertQueryResult">
        INSERT INTO tbltickets (ttDate,  ttType, ttTo)
        VALUES (<cfqueryparam cfsqltype='CF_SQL_timestamp' value='#CreateODBCDateTime(now())#'>
        ,<cfif IsDefined("FORM.ttDateDue") AND FORM.ttDateDue NEQ "">
            <cfqueryparam value="#FORM.ttDateDue#" cfsqltype="cf_sql_timestamp">
        <cfelse>
            NULL
        </cfif>
        ,<cfif IsDefined("FORM.ttType") AND FORM.ttType EQ "">
            <cfqueryparam value="#FORM.ttType#" cfsqltype="cf_sql_varchar" maxlength="30">
        <cfelse>
        </cfif>
        ,<cfif IsDefined("FORM.ttType")>
            <cfif FORM.ttType EQ "">
            <cfelseif FORM.ttType EQ "T1">
                <cfqueryparam value="serv1@xyc.com" cfsqltype="cf_sql_varchar">
            <cfelse>
                <cfqueryparam value="serv2@xyc.com" cfsqltype="cf_sql_varchar">
            </cfif>
        </cfif>
    </cfquery>
    Nov 19, 2012 2:46 PM   in reply to jlig
    If you want to update a value in a select based on the value of another form field, you have to use javascript.  I wouldn't bother.  I'd simply generate the email address I wanted when I process the submitted form.
    Nov 19, 2012 11:49 PM   in reply to BKBK
    On second thoughts, the following is more in tune as last term:
            <cfif FORM.ttType EQ "T1">
            <cfelseif FORM.ttType NEQ "">
            <cfelse>
            </cfif>
    <cfelse>
    </cfif>
    Dec 11, 2012 5:39 PM   in reply to jlig
    Regarding:
    I'm not sure how to "tie" the tblUsers (where the email address is) to the tblTickets (where the ttType is) and only send those people the email..
    Neither am I because I am not familiar with your database.  This is a rather long thread in which the topic has changed.  My suggestion is to start a new one that focuses on this particular problem.  Provide as much information about your database as you deem relevent.  Look for a table that has both a user id and a ticket id.
    Dec 12, 2012 12:06 AM   in reply to Dan Bracuk
    Hyear, hyear.
