CS6 hanging at measuring memory
Nov 16, 2012 6:40 AM
Greetings.
We have set up a new lab here on campus with 11 machines running CS6 for our art department. Currently those machines are W7 32bit with an I5 processor and 4gb of memory. They are brand new machines with a fresh image and install of CS6.
At random points of the day we have noticed that Photoshop will hang on measuring memory. We have noticed that this occurs any time an SVCHost process is running at more than 200k. We have tried to narrow down what exactly is causing the SVCHost to spike but have been unsuccessful. We have turned off windows update and virus scanning on those machine to no avail.
I was wondering if anyone had run into this issue on W7 before? We are kind of stumped at the moment and our professors are getting frustrated with not being able to have students use Photoshop when they need them too.
Thanks in adavance
    Nov 16, 2012 6:43 AM   in reply to JHusk828
    [Moved to the Photoshop forum]
    Nov 16, 2012 7:47 AM   in reply to JHusk828
    I had the same issue. Disabling the virusscanner didn't help, stopping the process neither. Only thing that helped was uninstalling my virusscanner completely. It was Comodo that I used.
    Nov 26, 2012 8:40 AM   in reply to JHusk828
    Other posts have sugggested it can be mismatched memory, or other processes.  Read this thread.
    CS6 really likes to run on 64 bit OS with min. of 8 gigs RAM.  Need to plug that into budget if you are going to run latest software.
  • Noel Carboni
    Dec 23, 2006
    Nov 26, 2012 8:48 AM   in reply to JHusk828
    Any chance these systems have volumes (e.g., drives with letters) that are sometimes disconnected (external) or unavailable (mapped network drives)?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Nov 26, 2012 10:36 AM   in reply to JHusk828
    If you let a Photoshop session that appears to be hanging just sit there for a few minutes, does it continue?
    I haven't seen any specific errant startup behavior owing to drive disconnects myself, but Photoshop does under some conditions check the drives in the system.  I do, for example, sometimes see a delay in the Preferences - Performance dialog until my disk drives spin up, even though I don't have any scratch partitions on those that are spun down.
    Another related possibility:  Is there a network printer in use in your environment that is sometimes offline?
    -Noel
    Nov 26, 2012 10:53 AM   in reply to JHusk828
    what happens if you shut down, disconnect the network and reset the Ps preferences on startup
    just a thought...
    Nov 26, 2012 11:04 AM   in reply to JHusk828
    At this point we are going to upgrade the memory and see if it helps because I am really out of ideas.
    To use more than 4 gigs of ram you need the OS to be 64bit as well as the program.
    Dec 10, 2012 11:38 AM   in reply to JHusk828
    Hello all - resurrecting this thread as it is the most pertinent to my issues.
    My CS6 is also hanging on "Measuring memory".  I've checked the network drives and devices and everything seems to be running fine... twice last week waited over 20min with no progression, today after 15min it 'wokeup'.
    Anything I can do to trouble shoot this more?  I'm not sure if there is some kind of log that I can retireve from somewhere?
    for my specs:
    Win7 Enterprise X64
    Intel Q9550
    8 GB ram
    any further info would be greatly appreciated.
    thanks!
    Dan
    Dec 10, 2012 11:54 AM   in reply to Dan_Vargas_26
    Something, most likely a drive or network volume, on your system is taking a very long time to access.
    You'll have to figure out what it is on your system that is taking so long -- probably by removing drives and drivers until the problem goes away.
    Dec 10, 2012 12:02 PM   in reply to Chris Cox
    Thanks Chris, it does seem particular to CS6 as I have just made the jump from CS5 and (CS4  before that) and have never had this issue before.  I do have a bunch of network drives that map on login.  Our techs tell me all network drives and devices were working during my hang.
    I just read in another thread that it maybe some kind of firewall blocking access to an address... http://forums.adobe.com/message/4707421 could this be the issue? we have MS Forefront here at the studio.
    D
    oh forgot to mention that when we re-installed nvidia drivers, this 'seemed' to get cs6 running again after a couple of 'hangs' (or what could have eventually been really slow loads)
    Dec 10, 2012 3:03 PM   in reply to Dan_Vargas_26
    Anything that prevents your machine from properly connecting to the drives mounted on your system, can cause such a hang.
