chapter playlist
Nov 16, 2012 12:27 PM
I'm looking at the chapter playlist capability in Encore CS6. My application is a video of a class (going to DVD now, but maybe Blu-ray in the future if client wants). The instructor offers various tips on how to do things throughout the class. I'd like to make a menu that includes just the tips. When the user picks one to play, I'd like it to play that tip section to the end of the tip, then return to the menu. In other words, I'd make each tip a chapter, play to the end of the chapter, then return to the menu. Is this doable? Are chapter playlists the correct tool to use for this?
No matter what though, the DVD has to be playable from end to end -- shove it in the slot, hit "play" and watch it to the end. Can I do both -- play it all the way to the end, and also play individual chapters that end by returning to a menu if that's where they were started from?
1) How do I identify the end of the chapter in question? I've searched all over the docs, and I can't find anything that references the end of a chapter. So I'm thinking that the only thing that identifies the end of one chapter has to be the start of the next chapter. Is that true, or is it something else?
2) If I have to identify the end of a chapter with another chapter marker, I can live with that. But can Encore? These would be chapter markers that I wouldn't use in a menu. They'd be exclusively for defining the end of a chapter if I have to do it that way. I have little doubt that Encore will tell me that I haven't used those particular markers -- but can I ignore the warnings and still get a usable playable DVD?
3) Where do I define the end action of returning to the menu? Would that be for the chapter marker at the beginning of the chapter? And if I do that, will it do anything to the normal "play all" action of starting the video and playing it to the end (which is the standard useage of the DVD)?
4) Finally, any free tutorials out there that explain how to use the chapter playlist features? The docs are, um, less than clear on the subject.
    Nov 16, 2012 12:59 PM   in reply to cfg_2451
    Short answer: you're guess are all good except for the end action that sends the "tip" back to menu. That end action is on each chapter playlist. No chapters will have end actions.
    I'll give a longer response in just a bit...
    Nov 16, 2012 12:58 PM   in reply to cfg_2451
    Are chapter playlists the correct tool to use for this?.
    Yes. The two alternative are overrides, which will work but seem to get most users into trouble, and making each chapter its own asset. Here, each tip will be part (not all) of the only logical subdivisions, so I don't think that is a good choice.
    The timeline itself will have an end action that goes back to its menu (or whereever you want). There will be no other end actions on the timeline, so it will play right through. The only disadvantage to having lots of "extra" chapter markers is that they will show up on DVD player displays, and the numbering may not fit what the viewers logic would dictate. Also, a user wanting to step through the "play all" option will stop at many chapters that will have no importance.
    Correct.
    I don't think you will even get a warning. It is common for there to be chapters on a timeline, and for there to be no buttons that link to them.
    Each "tip" chapter will be added to its own chapter playlist. The button for that tip will link to that chapter playlist. The end action will go on the chapter playlist. No chapter will have an end action.
    I can't find the reference I'm sure I have to a tutorial....
    Nov 18, 2012 1:56 PM   in reply to cfg_2451
    when the DVD player gets to the end of the chapter, it holds that last frame on screen while it does the file lookup for the menu that is the end action of the chapter playlist. Once the menu has been re-read, it puts that up on the screen. Just a couple of seconds. But it would have been nice if the chapter playlist instead got to the end of the chapter and then generated a black screen while pulling up the menu.
    I think this is actually by design in the DVD spec. There is more concern over seeing a black frame than a still of the last thing that was on the screen.
    But the intent is as little black or still as possible. Some black/still is not because of the spec but less than optimal coding. I am not expert enough in that to tell you whether your situation can be improved by things like pgcedit after you are doing in Encore.
