Hiding Browser URL
Nov 16, 2012 11:23 PM
Hi
Summary: I have a working input form. User information is captured. This form is posted around. I do not wish for the url of this page to be known.
Question:
How will I achieve this and What should I code? Where should I code it?
Source code:
<?php require_once('Connections/dbAttendance.php'); ?>
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
  if (PHP_VERSION < 6) {
    $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
  $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch ($theType) {
    case "text":
      $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
      break;
    case "long":
    case "int":
      $theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case "double":
      $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case "date":
      break;
    case "defined":
      $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
      break;
  return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
  $editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form")) {
  $insertSQL = sprintf("INSERT INTO attendlist (Windowsid, title, firstname, surname, extension, mobile, jobrole, course, cpg, mgrname, room) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
                       GetSQLValueString($_POST['textfield'], "text"),
                       GetSQLValueString($_POST['select'], "text"),
                       GetSQLValueString($_POST['textfield2'], "text"),
                       GetSQLValueString($_POST['textfield3'], "text"),
                       GetSQLValueString($_POST['textfield4'], "text"),
                       GetSQLValueString($_POST['textfield5'], "text"),
                       GetSQLValueString($_POST['select5'], "text"),
                       GetSQLValueString($_POST['select2'], "text"),
                       GetSQLValueString($_POST['select4'], "text"),
                       GetSQLValueString($_POST['textfield7'], "text"),
                       GetSQLValueString($_POST['select3'], "text"));
  mysql_select_db($database_dbAttendance, $dbAttendance);
  $Result1 = mysql_query($insertSQL, $dbAttendance) or die(mysql_error());
  $insertGoTo = "Thankyou.php";
    $insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
    $insertGoTo .= $_SERVER['QUERY_STRING'];
  header(sprintf("Location: %s", $insertGoTo));
$query_rsAttendance = "SELECT * FROM attendlist";
$rsAttendance = mysql_query($query_rsAttendance, $dbAttendance) or die(mysql_error());
$row_rsAttendance = mysql_fetch_assoc($rsAttendance);
$totalRows_rsAttendance = mysql_num_rows($rsAttendance);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Delegate Register</title>
<link href="Registerpage.css" rel="stylesheet" type="text/css" />
<link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
<link href="SpryAssets/SpryValidationSelect.css" rel="stylesheet" type="text/css" />
<script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script src="SpryAssets/SpryValidationSelect.js" type="text/javascript"></script>
</head>
<?php
$date = date(“format”, $timestamp);
<body>
<div class="container">
  <div class="header"><img src="Cerner At Imperial2.jpg" width="960" height="150" alt="" /><!-- end .header --></div>
  <div class="content">
    <h3>Register: <?php echo "Date  - ".date("d/m/Y - H:ia")?></h3>
    <form action="<?php echo $editFormAction; ?>" method="post" name="form">
      <table width="780" border="0">
        <tr>
          <td><div align="right">User ID *</div></td>
          <td><span id="sprytextfield1">
            <input name="textfield" type="text" id="textfield" tabindex="1" size="18" maxlength="10" />
          <span class="textfieldRequiredMsg">A value is required.</span></span></td>
          <td> </td>
        </tr>
        <tr>
          <td><div align="right">Title *</div></td>
          <td><span id="spryselect1">
            <select name="select" id="select" tabindex="2">
              <option value="0">Select</option>
              <option value="1">Ms</option>
              <option value="2">Mrs</option>
              <option value="3">Mdm</option>
              <option value="4">Dr</option>
              <option value="5">Mr</option>
              <option value="6">Prof</option>
            </select>
          <span class="selectRequiredMsg">Please select an item.</span></span></td>
          <td> </td>
        </tr>
        <tr>
          <td><div align="right">First name*</div></td>
          <td><span id="sprytextfield2">
            <input name="textfield2" type="text" id="textfield2" tabindex="3" size="30" maxlength="30" />
          <td> </td>
        </tr>
        <tr>
          <td><div align="right">Surname *</div></td>
          <td><span id="sprytextfield3">
            <input name="textfield3" type="text" id="textfield3" tabindex="4" size="30" maxlength="30" />
          <td> </td>
        </tr>
        <tr>
          <td><div align="right">Contact / Bleep *</div></td>
          <td><span id="sprytextfield4">
            <input name="textfield4" type="text" id="textfield4" tabindex="5" size="30" maxlength="30" />
          <td> </td>
        </tr>
        <tr>
          <td><div align="right">Mobile no: (optional)</div></td>
          <td><input name="textfield5" type="text" id="textfield5" tabindex="6" size="20" maxlength="20" /></td>
          <td> </td>
        </tr>
        <tr>
          <td> </td>
          <td> </td>
          <td> </td>
        </tr>
        <tr>
          <td><div align="right">Job Role *</div></td>
          <td><span id="spryselect5">
            <select name="select5" id="select5" tabindex="7">
              <option value="0">Select </option>
              <option value="1">Doctor</option>
              <option value="2">Nurse IP</option>
              <option value="3">Nurse OP</option>
              <option value="4">Midwife</option>
              <option value="5">Booking Clerk</option>
              <option value="6">Medical Secretary</option>
              <option value="7">OP Receptionist</option>
              <option value="9">CNS/NP</option>
              <option value="10">Tester</option>
            </select>
          <td> </td>
        </tr>
        <tr>
          <td><div align="right">Manager's Name *</div></td>
          <td><span id="sprytextfield5">
            <input name="textfield7" type="text" id="textfield7" tabindex="8" size="30" maxlength="30" />
          <td> </td>
        </tr>
        <tr>
          <td> </td>
          <td> </td>
          <td> </td>
        </tr>
        <tr>
          <td> </td>
          <td> </td>
          <td> </td>
        </tr>
        <tr>
          <td><div align="right">Course *</div></td>
          <td><span id="spryselect2">
            <select name="select2" id="select2" tabindex="9">
              <option value="1">Demo</option>
              <option value="2">Doctors</option>
              <option value="3">Nurse IP</option>
              <option value="4">Nurse OP</option>
              <option value="5">Midwife</option>
              <option value="6">Booking Clerk</option>
              <option value="7">Medical Secretary</option>
              <option value="8">OP Receptionist</option>
            </select>
          <td> </td>
        </tr>
        <tr>
          <td><div align="right">Location *</div></td>
          <td><span id="spryselect3">
            <select name="select3" id="select3" tabindex="10">
              <option value="1">CHX 12 Floor Rm 1</option>
              <option value="2">CHX 12 Floor Rm 2</option>
              <option value="3">CHX 10 West </option>
              <option value="4">HH N207 </option>
              <option value="5">HH W12 Conference</option>
              <option value="6">SMH Rm a</option>
              <option value="7">SMH Rm b</option>
              <option value="8">SMH Ming Wing Rm 5</option>
              <option value="9">SMH Ming Wing Rm 3</option>
            </select>
          <td> </td>
        </tr>
        <tr>
          <td><div align="right">CPG *</div></td>
          <td><span id="spryselect4">
            <select name="select4" id="select4" tabindex="11">
              <option value="1">CPG 1 - Medicine</option>
              <option value="2">CPG 2 - Surgery and Cancer</option>
              <option value="3">CPG 3 - Specialist Services </option>
              <option value="4">CPG 4 - Circulatory Services and Renal Medicine</option>
              <option value="5">CPG 5 - Womens and Children</option>
              <option value="6">CPG 6 - Clinical and Investigative Sciences</option>
              <option value="7">CPG 7 - Private Patients</option>
              <option value="8">Others</option>
            </select>
          <td> </td>
        </tr>
        <tr>
          <td> </td>
          <td><input name="button" type="submit" id="button" value="Submit" /></td>
          <td> </td>
        </tr>
        <tr>
          <td><div align="center">*Mandatory fields </div></td>
          <td> </td>
          <td> </td>
        </tr>
      </table>
      <input type="hidden" name="MM_insert" value="form" />
    </form>
<!-- end .content --></div>
  <div class="footer">
<p align="center">
    <a href="http://validator.w3.org/check?uri=referer"><img
      src="http://www.w3.org/Icons/valid-xhtml10" alt="Valid XHTML 1.0 Transitional" height="31" width="88" /></a>
      <p align="center"> Cerner@Imperial ICT Training Team </p>
</p>
  <!-- end .footer --></div>
  <!-- end .container --></div>
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "none", {validateOn:["blur", "change"]});
var spryselect1 = new Spry.Widget.ValidationSelect("spryselect1", {validateOn:["change", "blur"]});
var sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2", "none", {validateOn:["blur", "change"]});
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3", "none", {validateOn:["blur", "change"]});
var sprytextfield5 = new Spry.Widget.ValidationTextField("sprytextfield5", "none", {validateOn:["blur", "change"]});
var spryselect2 = new Spry.Widget.ValidationSelect("spryselect2", {validateOn:["change", "blur"]});
var spryselect3 = new Spry.Widget.ValidationSelect("spryselect3", {validateOn:["change", "blur"]});
var spryselect4 = new Spry.Widget.ValidationSelect("spryselect4", {validateOn:["change", "blur"]});
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "none", {validateOn:["blur", "change"]});
var spryselect5 = new Spry.Widget.ValidationSelect("spryselect5", {validateOn:["blur", "change"]});
</script>
</body>
</html>
<?php
mysql_free_result($rsAttendance);
    Nov 17, 2012 12:47 AM   in reply to Reynold Dreamweaver CS6
    If you don't want the URL to be known, don't run a web page. You could load it inside an iFrame or dynamically inside a script, which you can disguise further using Base64 encoding or similar or you could generate abstract URLs using PHP, but ultimately, if somebody wnats, they can still find out. You'd do better working authentication procedures, so only people who have a valid key can fill out and send the form...
    Mylenium
    Nov 17, 2012 5:49 AM   in reply to Reynold Dreamweaver CS6
    Which URL is it you want to not reveal?
    Nov 17, 2012 6:50 AM   in reply to Reynold Dreamweaver CS6
    Sorry - I still don't understand what it is you want to hide.  Can you just give me that information?
    Nov 17, 2012 7:35 AM   in reply to Reynold Dreamweaver CS6
    Which link?
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Nov 17, 2012 7:39 AM   in reply to Reynold Dreamweaver CS6
    This is a server-side question. As advised to you earlier once, you should post this in the appropriate forum for better (quicker) responses. I'm moving it there this time as well.
    First look - You are using server behaviors. Bad idea. How about writing custom-code - considering the work that you seem to be doing is quite comprehensive?
    Custom-code - Have you heard about AJAX? Posting a form while 're-directing' the user the the submission page is your problem - you've mentioned in your original question.
    If you use AJAX form validation/ submission, your user will not be taken to the submission page. They go to Page A, fill the form info, hit submit, AJAX validation happens and form is submitted in the backend. User is still in Page A - the only change happening on front-end being that the user sees a 'Message sent' or 'Form submitted' message.
    Eureka?
    Nov 17, 2012 9:47 AM   in reply to Reynold Dreamweaver CS6
    >I have been waiting over 8 hrs still no reply to the rest of my post
    Again, this is a user-to-user forum. We don't work for Adobe. Many of us may be in a different timezone that you and are sleeping while you are posting. Also note that activity on all of these forums is significantly reduced during the weekend. We all have lives and families. Complaining numerous times about lack of responsiveness on these forums seems like a slap in the face to those who have put a great deal of effort into assisting you.
    Now, back to your current question:
    >Can DW support this idea ?
    It can only support it in that it is a simple editor that will allow you to enter custom code you write.
    >Is there more to using server behaviour to try and code up this
    >type of behaviour required. Is this behaviour in DW server behaviour?
    >Is this where DW server behaviour ends?
    They ended long before this. They don't support AJAX calls, and based on your requirements, you should not be using them at all. I would avoid DW SB's because:
    1) They are intended for only the simplest web application functions
    2) They are not robust
    3) They do not meet todays coding standards
    4) They are overly verbose - most human written code is more concise and easier to read
    5) Once you modify them, DW dialogs can no longer maintain them.
    I suspect that they will be completely removed in upcoming versions.
