I have identified a bug in DW but there is still no acknowledge by Adobe Engineering Team. So what was the point of reporting when there is no efforts on their part to acknowledge such reporting.
Did you even read information on the bug report page before you submitted the 'bug' you 'identified'?
We normally do not send personal replies to feature requests or bug reports. We do, however, read each and every message. We use the information to improve our products and services. Your comments, suggestions, and ideas for improvements are very important to us. We appreciate you taking the time to send us this information.
Available here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Hi
Yes I did. This is probably the BIGGEST floor then. But it is a FLOOR in submitting and coming forward with the Bug. It is old school, there should be openess and communicatin when every effort is made to identify locate and report the error. Maybe a revamp of the bug reporting procedure. As user we need to be seen and acknowledge. As Engineers they need to communicate else there will be a stale mate.
Sorry you feel this way, but quite honestly I've submitted many, many bug reports to browser & software developers over the years. Rarely if ever do I receive a personal reply from them. Nor do I expect to. If developers spent all their time sending personal replies for every bug submission they receive, they would have no time to work on fixing bugs.
If you want a dialogue, join an official beta testing team.
Nancy O.
The most important thing is that the 'bug' you have identified and submitted actually be a bug. So far, I have not seen anything in any of your posts that would qualify as a bug. In addition, the bug must be repeatable - that means it must happen every time you execute a series of steps. Finally, you must describe (in detail) the steps required to demonstrate the bug. As I said, I have not seen anything that would meet these criteria yet.
Hi Murray,
Sorry you didnt see my other discoveries. It is a BUG, even as you said it and defined it. It happens every time.
I will post you the link to the bug.
The dicussion has thrown up a BUG but we were busy correcting it. It is the Insert>Data>Insert Record. POST is captilised. when it should only be lower case (I think you remember we had this conversion).
It is in the panels as well. So if you hand coded it you wouldnt have put it in the form action as captialised POST but lowercase POST. The panel does that. Hence, if you automate and generate the code from the insert record in the server side behaviours panel you get this.
I am glad you felt this way once but probably accepted it as the norm now. It is old school to ignore users.
Good idea to join the official beta testing team!
I was not looking for personal gratification or acknowledgement but just to see that the bug has been parked on a reporting list or some sort. It is not too much to ask!
Reynold Dreamweaver CS6 wrote:
... As user we need to be seen and acknowledge. As Engineers they need to communicate else there will be a stale mate.
You might find this interesting: http://blogs.adobe.com/dreamweaver/2012/11/join-the-dreamweaver-pre-re lease-group.html
I remember this conversation, and you are confused. The insert record server behavior DOES NOT WRITE ANY HTML. It requires that you have a page that already has a form on it. Try this -
1. Create a new PHP page.
2. Save it.
3. Try inserting an insert record server behavior on this new page.
You are told that before using this behavior, you must first insert a form. That means that *you* are the one responsible for putting an uppercase "POST" in the form's method attribute if that is what you are referring to. If, however, you are talking about PHP's use of the auto-global $_POST, then that is supposed to be uppercase. Neither of those is a bug.
Hi Murray,
I have created a new PHP page. Save it and now inserted record server behaviour on this new page. The post is in lowercase. I have inserted aform. I am not sure what makes you think I have not done so. It is impossible to insert a record server bahviour without the form creation first. The trouble is that I have created the form without EVEN touching this part of the code. So the capitalised code is an auto-code generation.
If I inform you that I did not touch that line why are you assuming I did.
Sorry - but this is mistaken. There is not a bug in that operation.
The insert record server behavior requires that you first create a page and insert a form on it. When you do that, the form is properly inserted according to your doctype and the settings in your PREFERENCES. There is NO bug here.
Hi Murray,
Thanks for reply. Will do eventually! I have a pressing matter to resolve at the moment which is an extension of the work on the form we have looked at. It is the case of duplication. I do not want a duplication flagged up on Click submit.
Sorry if I am changing subject, we will agree to park this until there is more time.
North America
Asia Pacific
