I attach a movie with:
exitapp_btn.addEventListener(MouseEvent.MOUSE_DOWN, fexitapp);
function fexitapp(event:MouseEvent) {
var mc:exitapp_mc=new exitapp_mc();
mc.x=320;
mc.y=210;
addChild(mc);
I would like the loaded movie to exit and move the parent movie to frame 4 (Is it possible?) . I currently have this:
import flash.system.fscommand;
nope_mc.addEventListener(MouseEvent.CLICK, cancelunloadexitb);
yep_mc.addEventListener(MouseEvent.CLICK, unloadexitb);
function cancelunloadexitb(e:MouseEvent):void {
this.parent.removeChild(this);
function unloadexitb(e:MouseEvent):void {
//I guess the code woul go here
Sure, but I'd still say stick to the "parent controls the child" concept.
Parent frame 1 with child (library clip) on screen:
stop();
// child calls this passing a reference of itself
function RemoveFunction(clip:Object):void
// any child calling this will be removed and advance
// this parent timeline to frame 4
removeChild(DisplayObject(clip));
gotoAndStop(4);
parent frame 4:
stop();
trace("Parent frame 4");
library MovieClip frame 90:
stop();
trace("Child now trying to run RemoveFunc
As in the real world, parents should control children, or at least collaborate. You should put a listener on your child and send the parent an event when you wish that to happen. The child removing itself from a parent can become a debugging nightmare.
You don't NEED to use an event for this but it can centralize a lot of what happens inside your app so I prefer this route. Otherwise yes you may run any public method on a parent from a child via MovieClip(this.parent).functionName();.
I'll demo the event version however:
Main FLA frame 1:
// import my child
import ChildClass;
import flash.events.Event;
stop();
trace("Creating child class (drawing a red circle for a visual)");
// I made it extend sprite because I assume yours is visual
// and it automatically supports events
var myChild:ChildClass = new ChildClass();
// add listener for my custom event
myChild.addEventListener("RemoveMe",_removeHandler);
// add to display list so event happens
addChild(myChild);
// function which receives event from child
function _removeHandler(e:Event):void
trace("Parent received event: " + e.type);
if (e.type == "RemoveMe")
// remove child, go to frame 4
removeChild(DisplayObject(e.currentTarget));
gotoAndStop(4);
Main FLA frame 4:
trace("Parent - I am on frame 4, there should be no circle");
ChildClass.as external class file:
package
import flash.display.Sprite;
import flash.utils.setTimeout;
public class ChildClass extends Sprite
public function ChildClass()
trace("Child created, drawing circle, waiting 5 seconds to send event to parent");
// draw a quick red circle
var c:Sprite = new Sprite();
c.graphics.beginFill(0xFF0000,1);
c.graphics.drawCircle(52,52,50);
c.graphics.endFill();
addChild(c);
setTimeout(_sendEvent, 5000);
protected function _sendEvent():void
// comm with parent who's listening for this
this.dispatchEvent(new Event("RemoveMe"));
Trace output:
Parent received event: RemoveMe
Hello Sinious:
Thnk you for your time.
Wow. that sure is a long route to accomplish somethig that seems very simple (removing an attached clip and pushing the main movie one frame)
I would not like to use an external class in this project. Is it possible to accomplish this through a shorter route? Any shortcut way to do this?
stop();
gotoAndStop(4);
parent frame 4:
stop();
stop();
trace("Child now trying to run RemoveFunction() on parent");
// send reference of this clip to function
Object(this.parent).RemoveFunction(this);
I'm using very generic types like Object and DisplayObject so it works from Sprites, MovieClips, Loaders and anything else that extends a DisplayObject.
trace:
Child loaded, playing..
Parent frame 4
If you really want the child to do it there's a second file (#2) that has the child do all the work.
The child MUST exist on the frame you want the parent to land on to remove itself or perform code.
Child on frame 90:
stop();
trace("Child now changing parent to frame 4, then removing self");
MovieClip(this.parent).gotoAndStop(4);
MovieClip(this.parent).removeChild(this);
Edit:
Note: If you load a child .swf via a Loader you'll need to consider that the clip is nested inside the .content property of that loader, making you have to parent out a bit more. Like if your code in your original post was from a SWF loaded via a Loader then to access the parent:
myBtn.addEventListener(MouseEvent.CLICK, _removeThisClip);
function _removeThisClip(e:MouseEvent):void
// I'm inside a loader, double parent out
MovieClip(this.parent.parent).gotoAndPlay(4);
MovieClip(this.parent.parent).removeChild(this.parent);
Sinious THAN YOU for your time and great examples. Based on your examples I managed to implement the solution.
Thank you
Att.,
Edwin
You're welcome and good luck!
