Hi
How should I handle this duplicate key? When I submit this form.
Source code:
<?php require_once('Connections/dbAttendance.php'); ?>
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
if (PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
switch ($theType) {
case "text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
break;
case "long":
case "int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
break;
case "double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
break;
case "date":
break;
case "defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
break;
return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form")) {
$insertSQL = sprintf("INSERT INTO attendlist (Windowsid, title, firstname, surname, extension, mobile, jobrole, course, cpg, mgrname, room) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
GetSQLValueString($_POST['textfield'], "text"),
GetSQLValueString($_POST['select'], "text"),
GetSQLValueString($_POST['textfield2'], "text"),
GetSQLValueString($_POST['textfield3'], "text"),
GetSQLValueString($_POST['textfield4'], "text"),
GetSQLValueString($_POST['textfield5'], "text"),
GetSQLValueString($_POST['select5'], "text"),
GetSQLValueString($_POST['select2'], "text"),
GetSQLValueString($_POST['select4'], "text"),
GetSQLValueString($_POST['textfield7'], "text"),
GetSQLValueString($_POST['select3'], "text"));
mysql_select_db($database_dbAttendance, $dbAttendance);
$Result1 = mysql_query($insertSQL, $dbAttendance) or die(mysql_error());
$insertGoTo = "Thankyou.php";
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
$query_rsAttendance = "SELECT * FROM attendlist";
$rsAttendance = mysql_query($query_rsAttendance, $dbAttendance) or die(mysql_error());
$row_rsAttendance = mysql_fetch_assoc($rsAttendance);
$totalRows_rsAttendance = mysql_num_rows($rsAttendance);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Delegate Register</title>
<link href="Registerpage.css" rel="stylesheet" type="text/css" />
<link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
<link href="SpryAssets/SpryValidationSelect.css" rel="stylesheet" type="text/css" />
<script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script src="SpryAssets/SpryValidationSelect.js" type="text/javascript"></script>
</head>
<?php
$date = date(“format”, $timestamp);
<body>
<div class="container">
<div class="header"><img src="Cerner At Imperial2.jpg" width="960" height="150" alt="" /><!-- end .header --></div>
<div class="content">
<h3>Register: <?php echo "Date - ".date("d/m/Y - H:ia")?></h3>
<form action="<?php echo $editFormAction; ?>" method="post" name="form">
<table width="780" border="0">
<tr>
<td><div align="right">User ID<img src="Asterick.gif" width="10" height="10" alt="" /></div></td>
<td><span id="sprytextfield1">
<input name="textfield" type="text" id="textfield" tabindex="1" size="18" maxlength="10" />
<span class="textfieldRequiredMsg">A value is required.</span></span></td>
<td> </td>
</tr>
<tr>
<td><div align="right">Title <img src="Asterick.gif" width="10" height="10" alt="" /></div></td>
<td><span id="spryselect1">
<select name="select" id="select" tabindex="2">
<option value="0">Select</option>
<option value="1">Ms</option>
<option value="2">Mrs</option>
<option value="3">Mdm</option>
<option value="4">Dr</option>
<option value="5">Mr</option>
<option value="6">Prof</option>
</select>
<span class="selectInvalidMsg">Please select a valid item.</span></span></td>
<td> </td>
</tr>
<tr>
<td><div align="right">First name <img src="Asterick.gif" width="10" height="10" alt="" /></div></td>
<td><span id="sprytextfield2">
<input name="textfield2" type="text" id="textfield2" tabindex="3" size="30" maxlength="30" />
<td> </td>
</tr>
<tr>
<td><div align="right">Surname <img src="Asterick.gif" width="10" height="10" alt="" /></div></td>
<td><span id="sprytextfield3">
<input name="textfield3" type="text" id="textfield3" tabindex="4" size="30" maxlength="30" />
<td> </td>
</tr>
<tr>
<td><div align="right">Contact / Bleep <img src="Asterick.gif" width="10" height="10" alt="" /></div></td>
<td><span id="sprytextfield4">
<input name="textfield4" type="text" id="textfield4" tabindex="5" size="30" maxlength="30" />
<td> </td>
</tr>
<tr>
<td><div align="right">Mobile no: (optional)</div></td>
<td><input name="textfield5" type="text" id="textfield5" tabindex="6" size="20" maxlength="20" /></td>
<td> </td>
</tr>
<tr>
<td> </td>
<td> </td>
<td> </td>
</tr>
<tr>
<td><div align="right">Job Role <img src="Asterick.gif" width="10" height="10" alt="" /></div></td>
<td><span id="spryselect5">
<select name="select5" id="select5" tabindex="7">
<option value="0">Select </option>
<option value="1">Doctor</option>
<option value="2">Nurse IP</option>
<option value="3">Nurse OP</option>
<option value="4">Midwife</option>
<option value="5">Booking Clerk</option>
<option value="6">Medical Secretary</option>
<option value="7">OP Receptionist</option>
<option value="9">CNS/NP</option>
<option value="10">Tester</option>
</select>
<td> </td>
</tr>
<tr>
<td><div align="right">Manager's Name <img src="Asterick.gif" width="10" height="10" alt="" /></div></td>
<td><span id="sprytextfield5">
<input name="textfield7" type="text" id="textfield7" tabindex="8" size="30" maxlength="30" />
<td> </td>
</tr>
<tr>
<td> </td>
<td> </td>
<td> </td>
</tr>
<tr>
<td> </td>
<td> </td>
<td> </td>
</tr>
<tr>
<td><div align="right">Course <img src="Asterick.gif" width="10" height="10" alt="" /></div></td>
<td><span id="spryselect2">
<select name="select2" id="select2" tabindex="9">
<option value="1">Demo</option>
<option value="2">Doctors</option>
<option value="3">Nurse IP</option>
<option value="4">Nurse OP</option>
<option value="5">Midwife</option>
<option value="6">Booking Clerk</option>
<option value="7">Medical Secretary</option>
<option value="8">OP Receptionist</option>
</select>
<td> </td>
</tr>
<tr>
<td><div align="right">Location <img src="Asterick.gif" width="10" height="10" alt="" /></div></td>
<td><span id="spryselect3">
<select name="select3" id="select3" tabindex="10">
<option value="1">CHX 12 Floor Rm 1</option>
<option value="2">CHX 12 Floor Rm 2</option>
<option value="3">CHX 10 West </option>
<option value="4">HH N207 </option>
<option value="5">HH W12 Conference</option>
<option value="6">SMH Rm a</option>
<option value="7">SMH Rm b</option>
<option value="8">SMH Ming Wing Rm 5</option>
<option value="9">SMH Ming Wing Rm 3</option>
</select>
<td> </td>
</tr>
<tr>
<td><div align="right">CPG <img src="Asterick.gif" width="10" height="10" alt="" /></div></td>
<td><span id="spryselect4">
<select name="select4" id="select4" tabindex="11">
<option value="1">CPG 1 - Medicine</option>
<option value="2">CPG 2 - Surgery and Cancer</option>
<option value="3">CPG 3 - Specialist Services </option>
<option value="4">CPG 4 - Circulatory Services and Renal Medicine</option>
<option value="5">CPG 5 - Womens and Children</option>
<option value="6">CPG 6 - Clinical and Investigative Sciences</option>
<option value="7">CPG 7 - Private Patients</option>
<option value="8">Others</option>
</select>
<td> </td>
</tr>
<tr>
<td> </td>
<td><input name="button" type="submit" id="button" value="Submit" /></td>
<td> </td>
</tr>
<tr>
<td><div align="center"> <img src="Asterick.gif" width="10" height="10" alt="" /> Mandatory fields </div></td>
<td> </td>
<td> </td>
</tr>
</table>
<input type="hidden" name="MM_insert" value="form" />
</form>
<!-- end .content --></div>
<div class="footer">
<p align="center">
<a href="http://validator.w3.org/check?uri=referer"><img
src="http://www.w3.org/Icons/valid-xhtml10" alt="Valid XHTML 1.0 Transitional" height="31" width="88" /></a>
<p align="center"> Cerner@Imperial ICT Training Team </p>
</p>
<!-- end .footer --></div>
<!-- end .container --></div>
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "none", {validateOn:["blur", "change"]});
var spryselect1 = new Spry.Widget.ValidationSelect("spryselect1", {validateOn:["change", "blur"], invalidValue:"-1", isRequired:false});
var sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2", "none", {validateOn:["blur", "change"]});
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3", "none", {validateOn:["blur", "change"]});
var sprytextfield5 = new Spry.Widget.ValidationTextField("sprytextfield5", "none", {validateOn:["blur", "change"]});
var spryselect2 = new Spry.Widget.ValidationSelect("spryselect2", {validateOn:["change", "blur"], invalidValue:"-1", isRequired:false});
var spryselect3 = new Spry.Widget.ValidationSelect("spryselect3", {validateOn:["change", "blur"], invalidValue:"-1", isRequired:false});
var spryselect4 = new Spry.Widget.ValidationSelect("spryselect4", {validateOn:["change", "blur"], invalidValue:"-1", isRequired:false});
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "none", {validateOn:["blur", "change"]});
var spryselect5 = new Spry.Widget.ValidationSelect("spryselect5", {validateOn:["blur", "change"], isRequired:false, invalidValue:"-1"});
</script>
</body>
</html>
<?php
mysql_free_result($rsAttendance);
