I've always wondered this but now it's beginning to bug me as I'm experimenting with layer stacking to reduce/modify noise.
If I have 2 layers at 50% opacity and a white layer underneath, those combined layers should equal 100% opacity and so I should not be able to see anything below the lower layer.
Instead what I find is that you have to stack over 15 layers at 50% before they even start to appear opaque (and at 15 they still aren't).
What's the math going on behind here? I would have assumed that, with an 8-bit image, you have 256 levels of transparency so at 50% you've got both layers at 128; 128-128 = 0 or no transparency so why does photoshop still allow something to be visible underneath that? While we're at it, why does 100% look fully opaque but 99% looks dramatically different without a layer underneath? Maybe the math is adding up but 50% opacity is actually more like 5% opaque?
Is there a blending mode I can use that will similate the build up of opacity more accurately? I'm really annoyed with the fact I can't really predict how layers are going to interact based on their opacity; I wish I at least understood the science behind it so I could alter my process to produce the results I want.
That makes sense - I guess what I'm wanting is a way to have 2 or more layers bound to each other and be able to adjust the blend of them together but always in a way that makes that set have full opacity.
A less confusing way of saying it is that I want to be able to have a bunch of layers and average out their pixel content, keeping the similar elements and filtering out their differences. Layer stacking produces a good simulation of this effect but I can't help but think that with 9 different RAW images I could be getting rid of a lot more noise than I am.
I guess I need to get a program catered specifically to that, I'm sure they exist. You would think exposure stacking would be something Photoshop or Lightroom would have integrated though - am I just forgetting where that option is? I seem to remember doing Focus Stacking with the layer blending/aligning options a while back.
Just set the layer below at 100% opacity and you achieve that.
-Noel
For some reason I was thinking that the layer at 100% was having too much influence on the look of the picture.
You were correct. If one layer is 100% opaque and the others are less opaque, then the 100% layer will have more influence than other layers. You're not going to calculate a mean image that way.
I've scored through that because I misunderstood what was meant. I guess it will give a mean of the layers if each layer has an opacity percentage of 100/n, where n is its position in the stack, with 1 being at the bottom.
Ps CS6 and CS5.1 (and maybe earlier) Extended feature image stacks that can calculate a mean image.
http://help.adobe.com/en_US/photoshop/cs/using/WS1E389632-4B37-425e-8E AB-1384C0B432D3a.html
With a standard version of Ps, floating point 32-bit mode can be used to calculate a mean image by summing your images and dividing by the number of images. Gamma adjustments in the process are required if your source images do not have a linear colour profile because Ps will convert them to linear on opening into a 32-bit document. Let me know if you want help with that.
Edit: see scored through paragraph.
That does not compute on my wetware, Conroy. Edit: I see you were editing while I was replying.
If the base layer is 100% opaque, and the layer above it is 99% opaque, which do you think will have more influence in the result?
Is there something unwritten being implied here that I'm being too dumb to pick up on?
Are you talking about stacking? If you want to average layers, you do it like this:
Nth layer: (100 / N) %
Fourth layer: 25%
Third layer: 33%
Second layer: 50%
Base layer: 100%
-Noel
Yes, the smart layer thing was exactly what I was looking for.
Unfortunately for me, it had literally the exact same results as just doing the manual layer stacking like you said (opacity = 100/layer#). In any case I'm glad I know about smart object stacking modes now! Thanks guys! I guess I'll just have to turn my ISO down a little if I really want noise free images ... I was trying to see if short high-ISO exposures looked better than really long low-ISO exposures. After 10 seconds my camera gets a lot of hot pixels (random white/red spots).
North America
Asia Pacific
