Piers-the-Ploughman
Illustrator is crashing
Nov 17, 2012 8:36 PM
Tags: #illustrator #crashing
I have CS6 version 16.0.2 (in the error reports it says 16.0 for  but i updated and problem persists)
Windows vista w/all service packs
Illustrator seemed to work fine for about a month but now will crash when I use color guide panel and open certain Harmony Rules (Complementary 2 is one, but there was another) and there were other crashes. the one documented below was for the Harmony Rules Comp 2 iirc
all of them give fault module of ntdll.dll though the Bucket ID is different on some, not all
and after updating to 16.0.2 the problem persists
thank you for any help
Report Sent
Problem signature
Problem Event Name:      APPCRASH
Application Name:           Illustrator.exe
Application Version:         16.0.0.682
Application Timestamp:   4f6e45b7
Fault Module Name:        ntdll.dll
Fault Module Version:      6.0.6002.18541
Fault Module Timestamp:                4ec3e855
Exception Code:                c0000005
Exception Offset:              0000000000048eb0
OS Version:        6.0.6002.2.2.0.768.3
Locale ID:           1033
Additional Information 1:                5461
Additional Information 2:                0e71338943f8c0a4b2f6e893b33c039c
Additional Information 3:                0906
Additional Information 4:                71a1a356601b7d259a221da8503e117b
Extra information about the problem
Bucket ID:          66163778
    Nov 18, 2012 12:05 AM   in reply to Piers-the-Ploughman
    Try by setting up a new settings folder like this
    1. Quit Illustrator.
    2. Rename the AIPrefs file (for example, to AIPrefs.old) in the Users/(user)/AppData/Roaming/Adobe/Adobe Illustrator CS6 Settings folder.
    3. Start Illustrator. Illustrator creates a new preferences file.
    Nov 18, 2012 2:18 AM   in reply to Piers-the-Ploughman
    ntdll errors are file access errors. As Wade suggested trash and repair your prefs as a first step. If the crash occurs when you use certain panels, you may have permissions issues on the files or the scripts used for the panels cannot access resources. Check that, too.
    Mylenium
    Nov 18, 2012 11:15 AM   in reply to Piers-the-Ploughman
    Adobe uses scratch disk space--virtual memory. So does Windows. At 73% filled up, you have virtually no accessable disk space.
    Take care, Mike
