Need help with Fluid Grid Layout and variable column balance.
Nov 18, 2012 2:13 PM
Tags: #column #background_color #balance #fluid_grid_layout
I'm using the fluid grid layout.  I have multiple columns that are actually fluid grid layout columns done by Dreamweaver.  I'd like them to extend as high as each other (all to the maximum height of each other) within the same section.  An added catch is that in the desktop layout, I have three side by side under one that takes the whole width of the page.  On tablet size, it's 2x2 in a square grid.  On mobile, they're vertically stacked.  I'm trying to get it so that background colour and/or borders looks decent and is fully balanced, no matter which layout is hit with the fluid layout.  The columns reflow, no problem.  But the height of any background and/or border is variable.
Any help on fixing this?
Example at:  https://music2help.thoughtburst.net/
The example doesn't have borders or colours, as it looked silly unbalanced.  The music2help.css is the only one I'm modifying manually.
Love the fluid grid layout, but I need a way to make it behave decently with backgrounds/borders.  Any help would be hugely appreciated!
Thanks!
mark->
    Nov 18, 2012 3:07 PM   in reply to Fairlight2cx
    CSS doesn't provide for equal height columns without hacks and other workarounds.
    This JScript works well on normal layouts. But I've never tried it with DW's Fluid Grids.
    http://www.projectseven.com/tutorials/css/pvii_columns/index.htm
    Let us know how it works.
    Nancy O.
    Nov 18, 2012 3:52 PM   in reply to Fairlight2cx
    Trust me when I tell you that Mat Taylor's Equal height layout approach is simply an illusion. The columns are not really equal height.  Owing to inherent limitations of Fluid Grid Layouts, his approach won't work for you.
    I'm starting to wonder about doing server-side includes of the div contents from a program which will read all three files and pad to the necessary amount of  <br/> lines to even things out.
    Don't even go there.  <br> tags are not a layout device and should never be used that way.
    Try the PVII script.
    Nancy O.
    Nov 18, 2012 3:59 PM   in reply to Fairlight2cx
    Adobe Fluid Grids is simply (no pun intended) not a good solution. It is
    extremely easy to learn and do multi-column layouts yourself with a
    fraction of the bloat and assurance of a long shelf life. If you are a
    CSS beginner I would recommend taking the time to learn. If you really
    need automation, then you might want to consider this:
    http://www.projectseven.com/products/tools/quick-columns/
    It simply (pun intended) works.
    Al Sparber - PVII
    The Finest Dreamweaver Menus | Galleries | Widgets
    Since 1998
    Nov 18, 2012 4:02 PM   in reply to Fairlight2cx
    The Adobe fluid grid system is not very obliging or forgiving with other
    CSS or some scripts. We would test it, but I get a little nauseous
    whenever I look at Adobe's code
    If you are really, really, stuck on continuing with the fluid grid
    thing, send me a link to a live test page and I'll take it down and test
    it with our EQH script.
    Al Sparber - PVII
    Since 1998
    Nov 18, 2012 4:03 PM   in reply to Fairlight2cx
    Nov 18, 2012 4:06 PM   in reply to Ben Pleysier
    @Gramps,
    The OP is using DW's Fluid Grid Layouts.  Display:table won't work with them.
    Nancy O.
    Nov 18, 2012 4:09 PM   in reply to Ben Pleysier
    That's also a good approach if older browsers are not a major concern.
    One point I would add to your article is that CSS table display
    essentially causes DIVs to act as if they were real tables, which can
    cause lots of frustration when trying to make an adaptive/responsive
    site. What you want to add to your method is the use of the table-layout
    property and set it to a value of "fixed". This will cause the element
    to render based on its assigned width rather than as a table cell which
    will expand beyond its declared with dependent on the content inside.
    The classic "gotcha" here is setting an image to max-width 100% will
    never work with display table-cell unless the table layout is fixed.
    Al Sparber - PVII
    Since 1998
    Nov 18, 2012 4:25 PM   in reply to Nancy O.
    @Nancy
    Oops! Thanks Nancy. Because I don't use DW's Fluid Grid Layouts, this completely slipped my mind.
    @Al
    Thanks. You know me by now, always trying to get a free-of-charge solution. I realise that these do not always work as is and that a paid-for solution can save a lot of time.
    Nov 18, 2012 4:41 PM   in reply to Ben Pleysier
    No problem.
    Free is not necessarily a bad thing and commercial is often a good
    thing. It depends on the situation. Of course, commercial is only good
    when the provider can guarantee satisfaction and provide the support to
    achieve it
    Al Sparber - PVII
    Since 1998
    Nov 18, 2012 5:49 PM   in reply to Fairlight2cx
    With all due respect, if you simply view the example pages below, you
    should be able to answer the questions yourself:
    http://www.projectseven.com/products/tools/quick-columns/examples/01.h tm
    http://www.projectseven.com/products/tools/quick-columns/examples/02.h tm
    Then, as you suggested, make your window narrow to emulate a mobile device.
    I'm afraid your link does not work. It presents a security alert.
    Al Sparber - PVII
    Since 1998
    Nov 18, 2012 6:05 PM   in reply to Fairlight2cx
    When writing a media query to reflow a column to which you have assigned
    an EQH class, you simply set height to "auto" with an !important
    notation and declare a max-height with a value of "888678px" with an
    important notation. This tells the script to remove that element from
    the height array.
    Look at the media queries for our example page in this file:
    http://www.projectseven.com/products/tools/quick-columns/examples/demo .css
    Al Sparber - PVII
    Since 1998
    Nov 18, 2012 6:09 PM   in reply to Fairlight2cx
    By the way, I went online and see your "Edit" note, but the URL is the
    same and most I can get to with any browser if I ignore the security
    alert is a log in screen.
    Nov 18, 2012 7:16 PM   in reply to Fairlight2cx
    I made a quick example - with one major breakpoint (for phones). These
    can be added to, of course.
    http://www.projectseven.com/testing/adobe-forums/music-to-help/
    The bottom line is that you can use it to learn, buy a product (and get
    support as you will still need to customize some things), or continue to
    use Fluid Grids.
    Fluid Grid is poorly designed, based on free tutorials that are no
    longer current, use an incorrect viewport meta tag, and code that is way
    over the top for the job.
    Any way you decide to go, best of luck to you.
    Al Sparber - PVII
    Since 1998
    Nov 18, 2012 7:31 PM   in reply to Fairlight2cx
    You're free and clear The EHC tutorial is free. You still are
    suffering from bloat with fluid grids, but sometimes is a price to pay
    for "free" - especially with Adobe add-ons.
    To clarify, I love Dreamweaver - but I've been around enough to be able
    to make darn good assessments of Adobe's "extras".
    Al Sparber - PVII
    Since 1998
    Nov 18, 2012 7:36 PM   in reply to Fairlight2cx
    To amplify my position, this recent post on our forum might be useful:
    http://www.pviiforums.com/topic.php?id=8776#post-13089
    Nov 18, 2012 8:49 PM   in reply to Fairlight2cx
    With a menu you need to reflow it, just like you do any other element.
    There are different approaches depending on the menu type. This is an
    example I did for a customer (actually on that same forum thread I
    pointed you to):
    http://www.projectseven.com/testing/customers/debic-forum/
    Just look at the media queries to see how I did it. It would work with
    any list-based horizontal menu.
    Another approach that works, but only for a single-level menu, is to use
    a scrollable list. It would be very complex to do with jQuery, but it is
    a built-in feature of our tabbed panel widget:
    http://www.projectseven.com/products/tools/tpm2/demos/
    If you notice, some of the tabs simply change panels, while others are
    live links. The UI allows tabs to be set as links only - with no
    associated content panel so it can be used just as a menu.
    Al Sparber - PVII
    Since 1998
