how to diagnose Acrobat problem
Nov 19, 2012 2:07 AM
Tags: #save_as_pdf
I've inherited/taken over my precursor's PC, which has FM 10 and CS 5.5 on. So far so good, but it didn't take long to hit a problem: Save as .pdf doesn't work :-{ I just get a couple of seconds' busy cursor, then a sort of bounce as though the entire screen is being redrawn, and that's it. No message, no log and no .pdf output.
This is the only FM installation in a fairly large company, and it must have been installed by ICT because it's on a closed PC. I'd like to gather as much background information as I can before contacting them.
Windows 7.0, as far as I know; FrameMaker 10.0.2.419 – just let me know if there's any more information you need.
Thanks in advance!
Niels Grundtvig Nielsen
    Nov 19, 2012 5:32 AM   in reply to Niels Grundtvig Nielsen
    Niels,
    Try printing to the Adobe PDF printer to make your PDF, instead of saving as PDF. In the past, there have been problems with saving to PDF.
    Van
    Nov 20, 2012 5:37 AM   in reply to Niels Grundtvig Nielsen
    Niels,
    If you are referring to the missing fonts issues, open all the files in the book, and then print the book to Adobe PDF.
    Unclear about your context menu comment, but psd is the extension for a Photoshop file.
    I am using version 9 and have never used save as PDF. I am not sure, but I believe the issue has been resolved in version 11 with some updates.
    Van
    Nov 20, 2012 10:17 AM   in reply to Niels Grundtvig Nielsen
    SO, did you uncheck Rely on system fonts only? I thought it was the other way round, namely to CHECK Relay on systems fonts only. In fact, the option is CHECKED in my setup; I just checked, no pun intended.
    Nov 21, 2012 8:39 AM   in reply to Niels Grundtvig Nielsen
    Niels,
    The SaveAsPDF has been working reasonably reliably in the last releases provided everything is installed correctly and the proper options are enabled.
    First, make certain that the Adobe PDF printer instance is the deafult in the FM session (use the SetPrint utility to ensure that it is).
    If you already had Acrobat installed prior to installing FM, then the default FM instalation also installs the PDFCreator add-on (you have to manually deselect it - very bad design on Adobe's part), which will hose the Acrobat installation. Try running the Repair option (under Help menu) in Acrobat. If that doesn't work, you may have to go through a re-install cycle.
    I also keep running into the "rely on system fonts" error message every so often. It seems like any Acrobat update that comes out resets the defaults the wrong way.
