Adobe Premiere 6.0.0 and Media Encoder 6.0.0.382 on Mac 10.6.8 using SSD drive for progams and OWC harddrive for projects/files.
I am working on CS6 CC, I finished a 20 minute edit. It has minor levels/3 way color, some warp stabilizer--but nothing external as of yet. I have about 5 video tracks and 10 audio tracks. This is my first export since upgrading to CS6--I am trying to export a h.264 HD vimeo file (tried both 720 and 1080).
My issue is that when I export either from premiere pro or from media encoder, the export time starts at about 2 and a half hours at first then slowly counts up instead of counting down. It has reached up to 130 hours (after exporting for 30 hours) before I stopped it to try a lower quality. I have been trying to export this project for four days. It seems that all three times I tried in media encoder, the time is still adding but the output preview is stuck on one frame (which was a different frame in each export).
I would say that I do not have the fastest and most upgraded computer, but I know that it worked fine before with CS5.
Thank you Joe for responding. I was very hopeful that this would be the solution. I removed all of the warp stabilizers and it appeared that it was working. The time evened out at about 4 hours but was still going up and down between 3-4 hours (at least it was going down at all). I left it with 2 hours left and I have come back to find it like it was before. The time is going up on the "remaining time" and the preview is stuck on the same image.
Has it stopped working? Or is it really taking this long? (And why is it stuck on the preview frame).
Thanks for any help in advance.
Hey bro i have same problem
Its been two days now cant find solution :(
I have 4 min clip and small effects on it
I m trying to match sequence export setting
JAnd it showing 11 hours
Please help
I m on 8 core machine
I even tried to export as h.264 codec
It says 18 hours ,.
Help please
Thanx
Is there some reason you have not installed the updates?
All Adobe updates start here and select product, read to see if you need to install updates in number order, or if the updates are cumulative for the individual product http://www.adobe.com/downloads/updates/
North America
Asia Pacific
