mitomatto
Bridge CS6 stops working keywords are updating???
Nov 19, 2012 7:48 PM
Tags: #bridge #crash #cs6
Everytime I try to update the keywords I always get an error and then Bridge shuts down!  Very frustrating!  Any suggestions?
    Nov 20, 2012 7:47 AM   in reply to mitomatto
    What OS, RAM, and what error message?
    Update keywords meaning adding new ones?
    Nov 23, 2012 3:25 PM   in reply to mitomatto
    I even totally deactivated and removed CS6, then reinstalled.... still cannot add keywords without the program shutting down!
    Nov 23, 2012 4:05 PM   in reply to mattkara
    How much hard drive space do you have?  Should have at least 10-20% free.
    Have you reset preferences by holding down Ctrl key and starting bridge.  Should get reset window.
    Nov 23, 2012 4:19 PM   in reply to Curt Y
    I just tried that... nothing changed.  i have about 15% free on my drive.   Tried to reset preferences on both Bridge and Bridge (64bit).  They both shutdown when I try to add keywords.
    Nov 23, 2012 5:09 PM   in reply to mattkara
    You said you tried resetng preferences.  Were you sucessful?  Did you get reset window?
    Try looking at the Event Log.  In the applications section for BRidge see if you can find Faulting Module.  THat is where problem lies.
    For event log check the OS Help file.
    Nov 23, 2012 5:29 PM   in reply to Curt Y
    Curt - thanks for your time and suggestions!
    The reset was unsuccesful for either BRidge or Bridge (64).  IT still did the same thing - closed the program down!
    Here is the event log...
    Faulting application name: Bridge.exe, version: 5.0.1.23, time stamp: 0x505aadb6
    Faulting module name: ntdll.dll, version: 6.1.7601.17725, time stamp: 0x4ec49b8f
    Exception code: 0xc0000374
    Fault offset: 0x000ce6c3
    Faulting process id: 0x2524
    Faulting application start time: 0x01cdc9d92f4bf692
    Faulting application path: C:\Program Files (x86)\Adobe\Adobe Bridge CS6\Bridge.exe
    Faulting module path: C:\Windows\SysWOW64\ntdll.dll
    Report Id: 8522233f-35cc-11e2-bcbc-3c970e1837f0
    Details:
    -System
    -Provider
    [ Name] Application Error
    -EventID1000
    [ Qualifiers] 0
    Level2
    Task100
    Keywords0x80000000000000
    -TimeCreated
    [ SystemTime] 2012-11-24T00:18:50.000000000Z
    EventRecordID15708
    ChannelApplication
    ComputerDeleted for security
    Security
    -EventData
    Bridge.exe
    5.0.1.23
    505aadb6
    ntdll.dll
    6.1.7601.17725
    4ec49b8f
    c0000374
    000ce6c3
    2524
    01cdc9d92f4bf692
    Nov 23, 2012 5:47 PM   in reply to mattkara
    Certainly not an expert on this, but this error frequently means a driver has crashed.  Check you video, printer, scanner, camera drivers.
    Feb 6, 2013 6:40 PM   in reply to mitomatto
    Hey,
    After  Granting permission and resetting preferences, (ctrl+launch + clear purge ) if it wont work.
    reinstall your adobe bridge:
    http://www.adobe.com/support/downloads/product.jsp?platform=Windows&pr oduct=108
    You might be installing it on drive other then your hard drive.
