MML and FM10
Nov 20, 2012 2:25 AM
Tags: #mml
Getting back up to speed, and hoping to use MML to move a lot of content into a new document – something I've been doing off and on since FM 7. Have things changed in 10 that I need to know about?
I've already noticed that  as the first line no longer seems sufficient for FM to recognise the filetype: seems that the extension now has to be .mml as well.  More serious, even a tiny source file [content below] with one style tag and two lines of content is triggering the inscrutable "Filter encountered an error and could not complete …" message.
I'll check it later today with FM 9  Hints and tips welcome! I just hope the answer will not be something obvious I've forgotten ;-}
N
--- source ------
<MML>
<!DefineTag :p>
<:p>this is a test paragraph.
<:p>extension .txt is not recognised as MML
    Nov 20, 2012 8:49 AM   in reply to Niels Grundtvig Nielsen
    Hi Niels,
    I think it migh be your use of the colon in the tag definition.
    The following works for me:
    <MML>
    <!DefineTag title >
    <!DefineTag h1 >
    <!DefineTag h2 >
    <!DefineTag p >
    <!DefineTag bib >
    <title>Chapter title
    <h1>Heading 1
    <p>paragraph text
    <p>more paragraph text
    <p>another paragraph
    <p>yet another
    <h2>Heading 2
    <p>The End
    <bib>some text
    Nov 21, 2012 8:48 AM   in reply to Niels Grundtvig Nielsen
    Niels,
    I just tried your sample verbatim and it worked with no problems (so it's not the colons).
    Could be the line endings. What editor do you use? Is there a return at the end of the last line (that sometimes trips things up)?
    Nov 22, 2012 7:58 AM   in reply to Niels Grundtvig Nielsen
    Try using just ASCII or ANSI modes in your editor.
