Hello,
I have a weird problem here. Today I opened my premiere pro project wich worked perfectly fine yesterday and the sound is offline in the timeline. hen I check in the bin it's ok. I tried to replace footage ith the same file but doesn't work. I used Pluraleyes to synchronise the sound and the image but I didn't import directly the XML in my project because I didn't want my files to be ther twice.
I opened the XML in another project and then imported a sequence from the project to my actual project (is that clear ?).
So today sound in the timeline is offline and I don't undestand why (maybe it has nothing to do with pluraleyes).
Thanks for your help !
I work on Windows 7
Intel Core i7
NVIDIA GeForce GTX 580
Hello, try this: select all the offline-audio-clips in the timeline, button right/audio channels.../ and re-configure the source channel "none/none" to "left/right". Works for me...
It´s occurs sometimes when you copy clips betweeen proyects, the configuration of the audio channels dissappear... Yes, weird.
Great news, and a "fix," that I would never have thought of - so I learned something from your thread too. Thanks for that.
Now, if Tatoz' suggestion solved the issue, you might want to look over this article: http://forums.adobe.com/thread/1058744?tstart=0 to better help Adobe support these forums, and to notify others, who come to this thread with similar problems, that you found a solution.
North America
Asia Pacific
