Pinchart
Extensions in Adobe X
Nov 20, 2012 8:57 AM
Tags: #extensions #acrobat_x
What if your version of Acrobat X doesn't have File > Save As > Reader Extended PDF > Enable Additions as an option?  How do you enable this feature?
  • George Johnson
    Aug 11, 2002
    Nov 20, 2012 11:46 AM   in reply to Pinchart
    Do you have Acrobat Pro or Standard? If Standard, what are the options under: File > Save As > Reader Extended PDF
  • George Johnson
    Aug 11, 2002
    Nov 20, 2012 5:42 PM   in reply to Pinchart
    Acrobat 7 is not capable of adding the necessary usage rights. It can only enable for commenting and the typewriter tool.
    The ability to Reader-enable a document so that Reader can save a filled-in form was first available with Acrobat 8 Pro. I'm not certain what you mean by Extensions manager, but LiveCycle Reader Extensions is the other software that's capable of adding usage rights, but it is quite expensive and is probably what you're thinking about. So you'll have to upgrade Acrobat if you want to enable the forms. The menu item you mentioned in your original post is for Acrobat 10. For 9 it's "Advanced > Extend Features in Adobe Reader".
