RedSchneb.photoshop.com
PSE 10 Cannot access Edit function Windows 7
Nov 20, 2012 5:42 PM
I have used Tech Support twice in past 4 months trying to get the Edit function to work.  Have reinstalled program twice from an On-line download license. When attempting to open EDIT, the system either cycle for 30 seconds and then simply disappears, or a pop-up appears "PSE 10 has stopped working" and cycles for 30 seconds and then closes the program.
    Nov 20, 2012 8:49 PM   in reply to RedSchneb.photoshop.com
    Please try couple of probable solutions as mentioned below:
    Solution 1:
    1. Close Elements.
    2. Launch the Photoshop Elements Welcome Screen and hold down ctrl + alt + shift as you click Editor.
    3. Continue to hold the keys until you see a message box asking if you want to delete Photoshop Elements settings file; click Yes. Elements will open with default preferences.
    Solution 2: In case any network printer is attached try to launch without network or printer uninstall or make different printer as default.
    Solution 3: Try launching with anti-virus off or removing PSE from conflicting list.
    Solution 4:
    On the drive on which you have installed PSE,on my machine it is on C:
       Go  to C:\Program Files\Adobe\Photoshop Elements  10\Locales\<locale>\Plug-Ins\Import-Exportand you will find twain  plug-in. Remove that plug-in from that location and copy it somewhere  else.
