KDJStent
How to fix stain on fine checkerd shirt with CS6.
Nov 20, 2012 5:15 PM
SampleSleve.jpgI have a photo of a white shirt with small black checks as a pattern. A large transparent yellow stain needs to be removed. The checks are one tenth of an inch square and one tenth of an inch apart. The original photo is lost and I have it at 200 ppi. Any help will be appreciated. Kevin Stent. kstent@xtra.co.nz
    Nov 20, 2012 10:03 PM   in reply to KDJStent
    Here's one approach:
    1. Use your eyedropper to sample color from the shirt, probably from a dark check.
    2. Copy that area of the shirt from the red channel and paste it in as a layer.
    3. Put an empty lyer above that, set it's blend mode to color, and paint braodly over the yellow area with the samled color from step 1.
    4. Use color range to make a selection of the yellow patch, then with the selection active make a curves or levels layer to add contrast to the yellow area, particularly to darken the checks in that area to match the rest of the shirt.
    That will take you pretty far, then you'll need to adjust/blend your edges/transitions by tweaking your masks, cloning or dodge and burning.
    This is my results using steps 1-4, the transitions would still need some tweaking:
    Edit: sorry the image is posting lighter than it appears in PS. Too late for me to figure out why.
