• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Contact Form Custom Thank you page
New Here ,
Nov 20, 2012 Nov 20, 2012
Is it possible to redirect a defualt contact form from business catalyst to a custom thank you page? Im setting up a mobile version of a website and want it to redirect to custom page with jquery mobile added to it
TOPICS
Content management and modules
Views
7.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Nov 20, 2012 Nov 20, 2012
To do this you need to append the following to your web forms action URL:
action=/FormProcessv2.aspx?........
change to:
action=/FormProcessv2.aspx?........&PageID=/Results
So you basically adding &PageID=/Results to the end.
Votes
Translate
Translate
LEGEND ,
change to:
Votes
Translate
Translate
Report
Report
New Here ,
so basically this part in the html
action="/FormProcessv2.aspx?WebFormID=48363&OID={module_oid}&OTYPE={module_otype}&EID={module_eid}&CID={module_cid}"
gets changed to
action="/FormProcessv2.aspx?WebFormID=48363&OID={module_oid}&OTYPE={module_otype}&EID={module_eid}&CID={module_cid}&PageID=/Results"
or is does it become
action="/results.html"
Votes
Translate
Translate
Report
Report
LEGEND ,
The first one.
And for nice code wise which I forgot to add change & to & which is the html entitiy of &
Votes
Translate
Translate
Report
Report
New Here ,
All right because coding is still new to me, I'm just a little confused. By adding "&ampPageID=/Results", you dont mean literally adding that verbatim? or does it become "&ampThanks.html=/Results"
Sorry for not understanding completely what you mean, I do a lot of graphic design work for websites and apps but never actually had to code one myself so this is a bit foreign to me
Votes
Translate
Translate
Report
Report
LEGEND ,
action="/FormProcessv2.aspx?WebFormID=48363&OID={module_oid}&OTYPE={mo dule_otype}&EID={module_eid}&CID={module_cid}&PageID=/Results"
Votes
Translate
Translate
Report
Report
New Here ,
Nov 21, 2012 Nov 21, 2012
But what is that doing to redirect my form to the custom thank you page? Don't I need to point to the "thanks.html" somehow?
Votes
Translate
Translate
Report
Report
Participant ,
Nov 27, 2013 Nov 27, 2013
action="/FormProcessv2.aspx?WebFormID=48363&OID={module_oid}&OTYPE={mo dule_otype}&EID={module_eid}&CID={module_cid}&PageID=/thanks.html"
Votes
Translate
Translate
Report
Report
New Here ,
Mar 31, 2014 Mar 31, 2014
How might I redirect to a custom Thank You page after using an Email Series web form where the form Action is different than above... action="/CampaignProcess.aspx?ListID=67952"
Using action="/CampaignProcess.aspx?ListID=67952&PageID=/thank-you.htm doesn't work. It still redirects me to "Newsletter Subscription: Your request to subscribe to this newsletter was successful."  Or can you just let me know where I can change this newsletter page's default text... I could just replace it with the html from my thank you page, but can't find where that is.
Would also like to disable the double opt-in but again, the documented way of doing this requires adding &OPTIN=true to the default form action, not the CampaignProcess.aspx above.  Any ideas?  Thanks!
Votes
Translate
Translate
Report
Report
New Here ,
Figured it out... put the optin code first, then the pageID code after it and it works...
action="/CampaignProcess.aspx?ListID=67952&OPTIN=true&PageID=/thank-you"
Votes
Translate
Translate
Report
Report
LEGEND ,
@mhartington
That is what I linked. As a note you do not need .html on your pages for pages to render. Clean urls
@getyler3
Yep, the redirect should be the very last paramater.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Feb 21, 2018 Feb 21, 2018
LATEST
Hi Liam
Are you able to recirect to a page on another url ? e.g.
CID=0&PageID=http://www.xyzco.uk/"> ?
Votes
Translate
Translate
Report
Report
