crites1
Moodle 2.3.2/Captivate 6/SCORM
Nov 20, 2012 8:08 PM
I am creating my SCORM Content with Adobe Captivate 6.
I use a Moodle site that is on version 2.3.2
Moodle doesnt completely cooperate with SCORM 2004, so I am using SCORM 1.2
My exam is a total of 120 random slide questions (from 7 different Question Pools) using the Submit All function.
I CANNOT FOR ANYTHING, GET MY RESULTS TO POST TO MOODLE.
I tried a trial exam and answered all the answers, the results show that I did attempt the exam but it is incomplete (False) and the score is Zero (also False)
Can somebody please help me out or point me in the right direction.
Zachary L. Crites
Tax Tech Inc.
taxtech5@ctitech.com
    Nov 20, 2012 8:19 PM   in reply to crites1
    Can you show screenshots of your SCORM settings in Captivate 6?
    Nov 20, 2012 8:30 PM   in reply to crites1
    I can't see anything too obviously wrong there.  Does it report correctly if you turn off Submit All and just submit each question separately?  There have been some weird issues with Submit All and I'm always suspicious now when I see someone mention it.
    The other thing I would try is to move questions OUT of your question pools for a test and see whether you can get scoring captured in the LMS without the question pools.
    Try getting a small simple project with just a few questions (no pools or Submit All) to work first with your current settings. Then if successful, start introducing other variables.
    Nov 20, 2012 8:35 PM   in reply to crites1
    OK.  That's interesting.  I wonder if Moodle (or Captivate) has some kind of question number limit.  Try increasing the number of questions by 10 each time to see if there's a point where it fails.
    Nov 20, 2012 8:37 PM   in reply to Infosemantics
    One more idea:  Do you have each question set to 10 points?  If so, set each to 1 point instead and see if that helps.  If you have a lot of questions set to 10 points, you might find that Moodle is using Raw Score instead of the percentage and the number of points exceeding 100 is giving it a headache.
    Nov 20, 2012 9:36 PM   in reply to crites1
    Try ticking the box in your SCORM settings for Interaction Data, then republish and test.
    Nov 21, 2012 3:46 PM   in reply to crites1
    Have you set up the interaction IDs for each question so that they all belong to the same set?
    Nov 21, 2012 4:36 PM   in reply to crites1
    OK.  This is a bit of a long shot, but can you show us a screenshot of your Project > Advanced Interaction screen so that we can see the Objective ID and Interaction ID shown for each of your question slides?  Compare the Objective IDs with the Objective ID shown under Quiz > Settings.  They should match for all questions.
    Another thing that occurred to me with your issue was to check the setting at Quiz > Pass Fail.  You showed us already that you have selected Percentage as the reporting method on the main screen, but there's another setting under Quiz > Pass or Fail to select Percentage or Score.  If you have Score selected here then that mismatch might be causing some issue.
    I would also recommend you check your Manifest dialog settings to make sure values are entered there.
    Nov 21, 2012 7:13 PM   in reply to crites1
    ZAC,
    Not seeing any screenshots.  Email attachments won't transfer into the forum post.  You need to insert them via the little camera icon on the toolbar.
    Nov 21, 2012 7:17 PM   in reply to RodWard
    The fact that you're using Question Pools might be significant because this can mean that the randomised question could be potentially of any type for a given attempt.
    Try moving some questions OUT of the pools and then republish to test in the LMS.  If the details start showing up in Moodle, we know the pools could be an issue.
    Nov 21, 2012 7:58 PM   in reply to crites1
    Interesting.  Then it would appear that this issue IS indeed related to some kind of numeric limit on what Captivate can handle.
    I recommend you log a bug for this.  I've never personally tried to put so many quiz questions into a single project, but in theory there should be no limit.
    Nov 24, 2012 2:47 PM   in reply to RodWard
    There is a limit to the amount of suspend data (aka resume data) that can be sent to an LMS.  It's 4096 character limit for SCORM 1.2 and AICC.  It's 64,000 characters (bytes) for SCORM 2004.  I wonder if you tell Captivate not to send resume data that it will correctly record all 120 questions.  You can find this setting in QUIZ --> Quiz Preferences --> "Advanced" button --> check "Never Send Resume Data".
    The consequences of turning this off is that your users will not be able to resume the course where they left off if they stopped in the middle of the quiz.  In other words, they should take the course/quiz in one sitting because Moodle will not be able to save their spot.
    HTH,
    Jim Leichliter
Bookmarked By (1)
