Squirell777
Flash URL Issue With Server
Nov 21, 2012 12:55 AM
Tags: #server #security #location
I am creating an internal site for our team. We use a shared drive at location:
\\xxxx\yyyyy\zzzzzz\ABC\
where I keep all of the html and swf files. When I try to get flash to open up another html file on the server it error's and says you need to make the location trusted in the settings. I have done this successfully many times for local locations on my PC - however I can't seem to get this to work for server based files.
Is there something I'm missing? How can I make the location given above a trusted location so the error box doesn't come up?
Thanks very much for any help you can offer.
Few quick specs in case they are relevant- running Windows XP, IE 7
Rob
    Nov 21, 2012 6:33 AM   in reply to Squirell777
    Adobe states not to work over a network so I'd recommend that as #1. It's not ideal but it's very published not to do so. Export locally and copy over to the network.
    What type of app is this? If it's browser based I'd recommend installing a web server and only viewing it via that. Opening SWFs off a filesystem requires different permissions for the SWF as well as non-trusted domain setups throw Windows into a turmoil (it trusts nothing by default, which is correct behavior).
    If you're making an application then this shouldn't be the case however but until you say that I'm assuming you're making something for the web or are trying to load a projector via a SWF.
    Nov 21, 2012 9:14 AM   in reply to Squirell777
    You unfortunately have no good solution here. Windows is far more complex than simply setting up a box and giving people a login. Windows will still treat it as a network source and therefore untrusted, as you're seeing. To make it trustable would be a topic for a Microsoft forum as it's pretty in depth on how to properly set up that environment. SWF will act as running locally off a filesystem unless you load it over a webserver so you can't get that built in behavior out.
    Finally, just to re-iterate, Adobe has always stated working over a network is simply not supported. Unfortunately your IT staff is removing the only shot you had at getting around that. It's very easy to enable a web server and still keep documents protected.
