Issue while configuring LiveCycle
Nov 21, 2012 2:19 AM
I have windows 7 64 bit.I downloaded the Live Cycle es3 server and tried installing.Installation went fine but when i went to the document to configure i see following missing files in the installation folder.
1)
To run Configuration Manager later, deselect the Start Configuration Manager option before you click Done. You can start Configuration Manager later using the appropriate script in the [LiveCycle root]/configurationManager/bin directory.
**I dont see this files in my installation directory.
2) I dont see any folder named  [LiveCycle root]/configurationManager/export.
3) Below files were mentioned to deply it on JBOSS.. i dont see these files either.
  • adobe-livecycle-native-jboss-[OS].ear
  • adobe-livecycle-jboss.ear
  • adobe-workspace-client.ear (
Let me know if i have misunderstood the doc
regards
Pushpendra
    Nov 28, 2012 6:41 AM   in reply to spushpendra2000
    [Livecycle root]  is just a generic placeholder. In practice the actual location could be different on each machine.
    If you did the default turnkey installation on windows you LiveCycle Root it will be something like C:\Adobe\Adobe LiveCycle ES3
    so the location of your file will be ...
    C:\Adobe\Adobe LiveCycle ES3\configurationManager\bin\ConfigurationManager.exe
    I am guessing because I have the ADEP LiveCycle installation which is
    C:\Adobe\Adep\configurationManager\bin\ConfigurationManager.exe
    anyway you can go to C:\Adobe and work from there
    If you are still having problems go to command line and search from ConfiguationManager.exe
    C: >dir /s configurationmanager.exe  - if you don't find it the was a problem with your installation you need to re-isntall
    Nov 29, 2012 12:24 AM   in reply to spushpendra2000
    Can you try the ConfigurationManager.bat file from a command line?
    Nov 29, 2012 1:59 AM   in reply to spushpendra2000
    If your installation was successfull, you should see the files as shown in the attached screenshot in your <LiveCycle_Install_folder>/configurationManager/bin directory.
    Nov 29, 2012 11:04 PM   in reply to spushpendra2000
    When you open the said url, you see a screen like
    When you click on the link "Download" just above where (1.4 GB) is written, it asks you for login and after you login, you see the screen as shown below :-
    Have you downloaded the build that i have marked above?
    Nov 29, 2012 11:33 PM   in reply to spushpendra2000
    Ideally you should have used the uninstaller. But, if it's not working for you then as the installation is currupt and we have no other option, you can delete the installation folder. And, then go an remove the entry from "Add/Remove Programs".
    Nov 30, 2012 3:32 AM   in reply to spushpendra2000
    There is no light weight installation available.
    After the installation, when you run LiveCycle Configuration Manager, then you can choose which components to deploy on your application server. For your use case, I think you need Forms and Output.
    Dec 3, 2012 3:39 AM   in reply to spushpendra2000
    This could be due to the earlier unclean uninstallation.
    You can try starting JBoss server and configurationManager from command line.
    For JBoss :-
    cd c:\Adobe\Adobe Livecycle ES3\jboss\bin
    run.bat -c lc_turnkey -b 0.0.0.0
    For Configuration Manager :-
    cd c:\Adobe\Adobe LiveCycle ES3\configurationManager\bin
    If you are still unable to run these, please attach the c:\Adobe\Adobe Livecycle ES3\jboss\servers\lc_turnkey\log\server.log file for jboss and c:\Adobe\Adobe Livecycle ES3\configurationManager\log\lcm.0.log for Configuration Manager.
    Dec 3, 2012 4:14 AM   in reply to spushpendra2000
    I believe you are using a 64 Bit Windows OS.
    The error above suggests that your JAVA_HOME is incorrectly set in environment variables.
    Please make sure that you are using 64 Bit Java and your environment variables are correctly set.
    Sample JAVA_HOME would be : C:\Program Files\Java\jdk1.6.0_34
    HTH,
    Hina Rastogi
    Dec 3, 2012 10:56 PM   in reply to spushpendra2000
    I have just installed that same build on my windows 7 - 64 bit  machine. And, I didn't get any such issue.
    Could you please try running the configuration manager in custom mode?
    do the below steps :-
    1.) Choose the livecycle modules that you want to install.
    2.) On the task selection screen, select like below :-
    if the deploy step fails to start jboss. then, do the deployment of ears manually (copy ear files form configurationManager/export directory to jboss\lc_turnkey\deploy directory, and start jboss manually).
    and then, do the remaining steps in order.
    Dec 4, 2012 12:51 AM   in reply to spushpendra2000
    You have the below line in the logs :-
    Caused by: ALC-PDG-30003-000: com.adobe.pdfg.exceptions.ConfigException: ALC-PDG-030-003-User account information for user root is not valid for the machine S4FFDV2 (172.26.32.87).
    This means that the username/password that you are giving is invalid. Your windows' machine administrator user is required here.
    Dec 4, 2012 1:33 AM   in reply to spushpendra2000
