Fruz75
Elements 11 problem with Saving to Version Set
Nov 21, 2012 3:35 AM
I have upgraded toElements 11 but when i go to save a file to " save in version set with original" it will not let me, as the  tick box is blanked out?
  • 99jon
    Jan 6, 2010
    Nov 21, 2012 3:41 AM   in reply to Fruz75
    On the menu click:
    Edit >> Preferences >> Saving Files
    Make sure the top dropdown is not set to “Save Over Current File”
    If it is change to Ask if Original or Always Ask
  • 99jon
    Jan 6, 2010
    Nov 21, 2012 9:41 AM   in reply to Fruz75
    Try opening another file, preferably an ordinary jpeg. Make a small adjustment and use File >> Save As
    Then check the Organizer box and version set box and save and then close the file using Ctrl+W
    If that works close Elements and re-launch and hopefully the settings will stick.
  • 99jon
    Jan 6, 2010
    Nov 21, 2012 10:23 AM   in reply to Fruz75
    It maybe a question of permissions. Are you running from an administrators account or a user account? If the latter do you have full read/write permissions for the application? What operating system do you have ?
    On Windows try making a direct shortcut for the Organizer and Editor. Make sure you have the correct file path as there is more than one exe file. You can then launch the programs directly from the desktop bypassing the welcome screen. This is generally better as the welcome screen leaves background processes running.
    Right click anywhere on the desktop and select New >> Shortcut
    Then click the browse button and navigate to:
    "C:\Program Files (x86)\Adobe\Elements 11 Organizer\PhotoshopElementsOrganizer.exe"
    Then click Next; then click Finish
    Then make a direct shortcut for the Editor in a similar manner.
    On Windows, Right click anywhere on the desktop and select New >> Shortcut
    "C:\Program Files (x86)\Adobe\Photoshop Elements 11\PhotoshopElementsEditor.exe"
    N.B. on 32 bit systems navigate to Program Files
    Right click on each of the new desktop icons and launch by choosing “Run As Administrator”
    Keep both applications running but try to edit and save a photo as before.
