wildbyte9951
Object > Crop Area > Make / Release
Nov 21, 2012 10:41 AM
Tags: #release #rectangle #make #artboard #fit #crop_area
Hi all.
I was using Illustrator CS3.
I need to make a rectangle fitted exactly to artboard.
I was using Object > Crop Area > Make, and then Object > Crop Area > Release
Now I am on Illustrator CS6 and this options are missing.
How can I do the same on CS6?
Best Regards.
    Nov 21, 2012 10:50 AM   in reply to wildbyte9951
    Use the artboard. In the Export dialog check the box at the lower left. You can also select among multiple artboards if you have them. To export jus a portion of the artwork, draw a box and go to Object>Artboards>Convert to Artboard and use the number of the new artboard for the export.
    Nov 21, 2012 1:19 PM   in reply to wildbyte9951
    Did you try what I told you? This is the replacement for the Crop Area from CS3. Are you working on an artboard which is the exact size you need for saving or do you need to crop the artboard area tighter? What format are you saving to?
    Nov 21, 2012 3:34 PM   in reply to wildbyte9951
    What happens when you just Save the file as an EPS. It will automatically use the artboard.
