Hello again:
In a TabbedViewNavigatorApplication, I´d like to show a Spark Fade effect on tab transitions. What I´m trying to do now is to apply a fade-out effect on the current tab´s active view, before selecting the new tab. I was able to do a event.stopPropagation() at "onIndexChanging" to avoid inmediate tab selection, and play the effect to fadeout the current view. But once the effect is finished, I simply don´t know what to do to continue with the events actual objective (that is, select a new tab).
Any ideas?
Thanks in advance.
<components:TabbedViewNavigatorApplication ...>
<fx:Declarations>
<s:Fade duration="{ParamsModel.timeoutFadeOut}" id="fadeOutEffect" alphaFrom="1.0" alphaTo="0"/>
</fx:Declarations>
<fx:Script>
<![CDATA[
protected function creationCompleteHandler(event:FlexEvent):void
this.tabbedNavigator.addEventListener(IndexChangeEvent.CHANGING, onIndexChanging);
// The navigator tab index is changing to event.newIndex
protected function onIndexChanging(event:IndexChangeEvent):void
event.stopPropagation();
fadeOutEffect.addEventListener(EffectEvent.EFFECT_END, function(event:EffectEvent):void
// NOW THE FADE EFFECT HAS ENDED, PROCEED TO SELECT THE TAB NORMALLY, BUT HOW??
// Play the effect on current view to fade it out
fadeOutEffect.play([tabbedNavigator.activeView]);
</fx:Script>
<components:navigators>
<components:ViewNavigator id="nav1" .... />
<components:ViewNavigator id="nav2" .... />
</components:navigators>
</components:TabbedViewNavigatorApplication>
Once the CHANGING event is listened, and after stop it, I tried to dispatch the CHANGE event manually after running some actions, with no luck:
// DO SOME STUFF
// Now, proceed and select the tab
var changeEvent:IndexChangeEvent = new IndexChangeEvent(IndexChangeEvent.CHANGE, false, false);
changeEvent.oldIndex = event.oldIndex;
changeEvent.newIndex = event.newIndex;
dispatchEvent(changeEvent);
The CHANGE event is dispatched, but the selected tab didn´t change.. Any ideas?
Thanks in advance
North America
Asia Pacific
