dustin.kerstein
Quick select cut/paste doesn't match 100%
Nov 21, 2012 11:41 AM
Tags: #cs6
I'm trying to cut out a selection using Quick Select (all refine edge settings off) and then paste into a new layer. However, I can't get a 100% pixel perfect alignment once I paste. Cut/Paste using the rectangle select does match 100%. The quick select tool should allow for 100% pixel perfect alignment, correct? Any pointers?
Dustin
This is before cutting (note middle circle)
This is after cut/paste and aligning
    Nov 21, 2012 11:49 AM   in reply to dustin.kerstein
    If you want the best selection tool you will need to do it yourself with the Pen Tool.  Little bit of a learning curve but results are worth it.
