William Scheer
Elements11
Nov 22, 2012 4:20 AM
Is there a way to shut off or move the confirm reject button in elements 11 when adding text? The Icon gets in the way when adding text to the bottom of a photo.
  • 99jon
    Jan 6, 2010
    Nov 22, 2012 4:27 AM   in reply to William Scheer
    It can bit a bit annoying. The easiest method, when you finish typing your text, is to select the move tool from the top of the tools pallet. Then drag the bounding box handles so that part of it appears below and outside of the image. You can then use the upper handles to position and scale your text precisely.
  • 99jon
    Jan 6, 2010
    Nov 22, 2012 4:47 AM   in reply to William Scheer
    Yeah click the accept button then choose the move tool. It should then work.
  • 99jon
    Jan 6, 2010
    Nov 22, 2012 5:54 AM   in reply to William Scheer
    Nov 22, 2012 6:23 AM   in reply to William Scheer
    Sorry to say but in PSE 11 you cannot move the position Confirm/Reject button. They will move along as you type text.
    Nov 22, 2012 2:08 PM   in reply to William Scheer
    After selecting the Text tool, just click to put your cursor anywhere in the picture above the very bottom of the picture, and the Confirm box will then be below the cursor. As others have said, then you can click on the Confirm check icon, then move the text to the very bottom of the picture with the Move tool.
Bookmarked By (2)
