From Indesign to Illustrator characters lost transparency
Nov 22, 2012 4:20 PM
I'm wondering, Is there a way to export an .indd file to .ai file in the export panel?
I got this current image in InDesign, the title is nice and melting well with the background
Now I export the work in .eps (only choice available for me) to work in Illustrator
and I get this
What happened? how to make it right like in the first pic in InDesign case?
Thank you very much
    Nov 22, 2012 4:40 PM   in reply to kililio
    when you export as EPS your transparency gets flattened--hence the white box--export as an unflattened PDF--then place that file.
    (it's also possible that the white box is due to the 'preview' settings, check by going to VIEW>DISPLAY PERFORMANCE>HIGH QUALITY DISPLAY)
    note: your workflow is kinda backwards--most designers build their art in illustrator--save as an .ai file then place that into InDesign.
    note also:  you can place an Indesign file into another Indesign file (although it won't be editable using this method)
