Please see this thread for further information:
Photoshop-Team says its an error with Indesign, not an error with Photoshop.
@Laubender: I already wrote about this workaround at the link. But its only that - a workaround. Most printers only accept flattened 1.3 PDFs and I would like to be able to open PDFs created from other people whom I have no control over how they export. And its definitely a problem only occuring with CS6, in CS3 everything was fine.
Any printer such as that should be avoided at all costs. Live transparency has been a fact of life for 10 years now and PDF X/4 is now a widely accepted standard for printing. X/4 includes not only live transparency but RGB as well.
Bob
That might be correct for the US, but in Europe its still widely the only accepted version. I just checked to be sure and looked at the 10 biggest online-printing companys and ALL only accept 1.3. Even specialised "offline" printers only accept 1.3, with anything newer being an exception not the norm.
Like I said…I can’t and won’t speak for Adobe. But X/4 is the standard today and it works with any modern workflow. Any workflow that requires a flattened PDF is incredibly old.
Today, flattened PDFs are considered by most, including myself, to be a workaround, not the other way around.
Bob
Not really true. The Ghent PDF Workgroup has officially approved its 2012 standards that are now based on PDF/X-4 with live transparency. We expect that most if not all European print associations will endorse this within the next year and their members (most European printers) will be required to accept PDF/X-4 per the Ghent PDF Workgroup standards.
- Dov
@Dov – let us hope, that PDF/X-4 will be adopted soon; by every printing company.
Just an additional note:
some of the biggest European online printers demand PDF/X-3 with restrictions that in effect mean you have to deliver a PDF/X-1a with fonts converted to outline paths. This is really rediculous…
PDF/X-3 has it's own problems and I would never recommend using that standard as export format. Either the old PDF/X-1a or (much, much better) PDF/X-4. For the online printers mentioned above I use always PDF/X-1a disguised as PDF/X-3. No "technical" problem here. It's just a hack, because PDF/X-1a can be regarded as a subset of PDF/X-3.
But I made that point already on another thread a couple of months ago…
Regarding the thread, that the OP has linked to:
I cannot understand that a professional workflow is based on rendering PDFs in PhotoShop.
This might be good for illustration purposes, but as a direct output-to-device workflow? I don't know…
Uwe
PPA Pass4Press still recommends using PDF/X-1a Acrobat 4 1.3
Bob or Dov, We have used the PPA Pass4Press settings for years, are there any other print production guidelines we should adopt?
As indicated in this thread, Adobe most strongly recommends use of PDF/X-4!
If your print workflow uses any RIP or DFE (Digital Front End - RIP for digital print engine) that has the Adobe PDF Print Engine (or even versions of Global Graphics' Harlequin technologies from the last half dozen years), you are actually degrading your printed output unless you use PDF/X-4 with live transparency and color management!!!
- Dov
North America
Asia Pacific
