SJRob
Loading or saving data with createJS in html5
Nov 23, 2012 6:37 AM
Tags: #flash #data #saving #html5 #cs6 #loading #syntax #createjs
Dear all,
Trying to find syntax and method for loading or saving data in html5 output. What is best practise and where to put in the createJS.........html or .js script? Of course that data needs to be available for movieclips, buttons, text, etc.
Used to using php or asp to get data with the old as3 loading methods, but unsure of what will work with the createJS side of things.
I am not doing any scripting in the flash file (as advised !) so it's all new working with the createJS. I've got buttons, clicks, etc working.
Is there any refrence sources on syntax and processes using the createJS that work with the flash html5 output?
Cheers
Steve
  • kglad
    Jul 21, 2002
    Nov 23, 2012 7:10 AM   in reply to SJRob
    you won't use createJS to create the code you need to load and save data.
    you will add javascript to the exported html5 project created by createJS to code for that data handling (and everything else).  i recommend using jquery but you can old-school your project using ajax.
