btaylor15
Image problem - can't add text before an image, only after
Nov 23, 2012 7:01 AM
Tags: #images
I've imported an image into my document, and I want to add text before the image. When I reach the end of the text line, the next line of text begins below the image. I want it to continue before the image an push the image down as I add more content. Any help would be much appreciated.
    Nov 23, 2012 7:04 AM   in reply to btaylor15
    Sounds like wraparound properties - check that out in the help
    Nov 23, 2012 7:34 AM   in reply to btaylor15
    isn't there a "none" setting?
    Nov 23, 2012 8:04 AM   in reply to btaylor15
    Select the frame. Look at Special > Anchored Frame > Anchoring Position
    Typically, it needs to be Below Current Line, or
    Run into Paragraph, Alignment [ Right ]
    The text you type for "Below..." need to be before the frame anchor symbol, otherwise it will flow below the frame. You'll need to have
    View [*] Text Symbols
    on to see the anchor.
