I hope this doesn't sound to crazy but the folks on the vegas forum couldn't help. I stopped using vegas pro 12 but my other editor just finished a wedding that was edited on vegas (our last one on vegas) and here lies the rub.
We have Premier cs6 with neat video installed. I need to apply neat video ( only licensed for PPcs6) to a few clips that have been edited in vegas 12.
I tried the export function in vegas and it left a few things out when it showed up in ppcs6 so that doesn't seem to work well. I was thinking about taking each clip and send them over to ppcs6 unedited and was wondering if they would come back to vegas with the effect on the timeline as they are cut up now. If the effect would be added to the files if rendered back out to vegas?
Any ideas appreciated beyond this would be excellent.
Thank you. Lovin the transfer to Adobe!
D
It is Hd Bill. I did get the files into PPcs6 but they were missing a few text files and some audio was out of sync after the export. Also the quality after being asked to change settings for ppcs6 to the exported vegas files seemed abit sharper and grainier in ppcs6. Strange.
Jim it is two seperate files that are 40 mins long but they are all cut in a multitrack in vegas. The editor didn't understand that we had neat video only for PPcs6 ; )
Thank you.
For HD, I would look into either Lagarith Lossless, or UT Lossless, both free. Once installed, I would anticipate (have never used Vegas) that you can Export to one of those, for Import, with no loss in the quality. Now, why Vegas is loosing things, I cannot imagine, or address.
Tittles in most NLE's do not carry to another NLE's.
The Audio will need to be imported into Prcs6 and resynced.
However, there is a work around.
you SEQ is Synced in Vegas so just export a Lossless or DVCPro version. I believe that page up/down moves between edits.
Use this to Note your cut points.
Open premier and import the exported loosless file.
You can type the Timecode right into the marker position and use the blade to recut your edit points.
Then FINISH in Pr because there is no reason to use vegas over Pr. My assistant uses Vegas10 nicely at home but he uses Pr in the office.
That is what I thought but the files are mt2 in vegas and I can't find a mt2 render extension in ppcs6 to drop over the originals in vegas for seamless export /import. I did find out guys that the export in vegas does not allow me to choose what codec I want to export to PPcs6. Go figure. LOL back to the boards again.Sad
It doesn't necessarily need to be in the same codec and wrapper. In fact, it's better if it isn't because that would introduce another layer of compression. The UT codec in an AVI file is a good choice for this task.
I would assume Vegas has some capability to replace a clip in a bin with another clip. That's how you'd go about it.
So I should render out AVI since vegas will not let me choose my codec to export? The footage looks a little more sharp and grainy when I export to ppcs6 via vegas's automatic setup.
But since the clips are multitrack cuts in vegas upon bring back in I would have to find each and everyone of those spots that were edited and resync them? If that was the case it would take a very long time to try to resync these.
I was under the assumption I could drop the new ppcs6 files back to vegas on each cut and they would resync. But If I remember right vegas upon dropping each one in reverts back to the beginning of the fil being dropped in losing sync of the actual cut spot. Hmmm.
Thank you as well Jim. I am going to try this now. Question .The original clip I should copy to another location but why should I rename it? Vegas will upon opening the edit will ask for where this file is. If I just ask it to use another file instead (different name) should that be fine. Then if all goes wrong I can ask vegas to use the original file again?
If one were trying to Import/Open the Vegas (or other) Project into PrPro, I could understand that.
However, if one is doing a full Export of the Timeline, to an "intermediate" AV file, the Titles, and any synthetic video, should be included in that Exported file. If they do not, then there is an issue with the NLE being used to Export.
In PrPro, the Titles are just XML code, within the PRPROJ (Project) file, but when one Exports, that XML code creates physical Titles, within the Exported AV file. Same for Black Video, Transparent Video, Color Mattes, etc..
I tried this a few times and the original file properties is this:
File Path: I:\Bri neat video\Clip 032.m2t
Type: MPEG Movie
File Size: 9.4 GB
Image Size: 1440 x 1080
Frame Rate: 23.976
Source Audio Format: 48000 Hz - compressed - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Total Duration: 00:49:42:21
Pixel Aspect Ratio: 1.3333
But when I go to export the file out the source out goes to 720 rather than 1440. I can't seem to get this back to 1440 for the out. Strange.
Thanx Jim. I did get it to work this way. Only thing is it was a bit tight on the screen edges for a widescreen. I believe the original was 1440x1080 x 24 and the one that PPcs6 exported was 1440x1080x 12. I don't know how you can change the end from 12 to 24 if this makes any sense. I need to learn what this is. ; )
It's the color bit-depth of the image from what I just found here. http://www.dvinfo.net/forum/what-happens-vegas/493267-video-file-prope rties.html
Explains it pretty well.
North America
Asia Pacific
